Old 02-21-2010, 06:22 PM
fmhsgrad96 fmhsgrad96 is offline
Exclamation 96 S10 Ignition/Starting Issue
I have a 1996 S10 with 187,000 miles on it. I have been experiencing lately an issue and not sure what might be the cause.
When I turn my key to the "run" position (before starting) is where the issue takes place. Normally when I turn the key to this position I get all gauge functions including the gauge indicator lights coming on. I then can start the truck.
Lately when I put the key in the run position there are no gauge functions or lights and the truck will crank but will not fire. This is an intermittent problem and I am wondering if there is a relay that is going bad or something else going on. The following items were replaced recently for one reason or another.
Timing chain, timing tensioner, #1 injector, all 4 intake valves, ignition coils, plugs, wires....
Old 02-22-2010, 10:43 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 96 S10 Ignition/Starting Issue
Check ign switch and all power feeds and fuses.
MT
Old 02-22-2010, 09:47 PM
Darren509 Darren509 is offline
Does sound like a bad switch. Try doing a search in this forum for ignition switch for details on which wires to check for power.
Old 05-20-2012, 07:35 PM
whitedavidp whitedavidp is offline
Hello. I have a '95 2.2L S10 that is exhibiting exactly the same symptoms as yours. Did you ever find a solution to this problem? Thanks
Old 05-25-2012, 06:07 PM
FishFind FishFind is offline
One Hot Shot
That was the only time the guy came to the forum. Has not been back after that. Most of the time it is the ignition switch.
Old 05-25-2012, 08:19 PM
Thanks for your post. I have done a bunch of googling and have decided that the switch is indeed the culprit. At least I hope so as I have just ordered one. I will post what I find so others will know. Cheers!
Tags
gauges , ignition , relays , s10 , starting
