Old 03-29-2012, 09:39 AM
vinnievv vinnievv is offline
Unhappy 1993 Blazer problem with brake system
Yesterday I had to slam on my brakes. The left wheel locked up and the truck slid a little. Now anytime I apply the brakes the left wheel seems to lock up after I depress the brake pedal half way and I hear a whining sounds like a motor turned on. Is it the ABS System? and where is the fuse located for the ABS? is it in the fuse panel or under the hood?
I appreciate any help anyone would provide
Thank you,
Vinnie
Old 03-29-2012, 12:03 PM
j cAT j cAT is offline
Re: 1993 Blazer problem with brake system
Thank you,
Vinnie
pull off the wheels and check the brake calipers . could be the caliper/pads/rotor etc are defective.
if the wheel locks up the ABS should come on...
could very well be a broken rotor.
The Following User Says Thank You to j cAT For This Useful Post:
vinnievv (03-29-2012)
1999 Chevy Blazer problems with Brakes mcelroy420 Problem Diagnosis 12 01-15-2007 03:14 PM
Need help with brake system for my trailer package..read inside... Ulysse Sierra 6 09-05-2006 05:59 AM
Help with braking system Morrell M Bodies 2 05-14-2006 12:04 PM
1995 blazer problems with brakes nmoran429 Blazer 9 08-03-2005 12:31 AM
Problems with Sound System DXJAGUAR Neon | Plymouth Neon 0 01-08-2004 05:59 PM
