Old 07-25-2005, 02:05 PM
nmoran429 nmoran429 is offline
Send a message via AIM to nmoran429
Unhappy 1995 blazer problems with brakes
Ever since I bought my blazer, I have only had the "regular brakes" I havent been able to use the ABS. Im not sure if it is a sensor, or computer malfunction, but I want to get them fixed. Both the Brake light and the ABS lights are on. I just hope that I wont cost an arm and a leg, but I also hear that the dealership may be able to fix them through a recall act. Is this possible? Someone please help!!
Old 07-25-2005, 04:39 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 1995 blazer problems with brakes
You will have to go get the codes scanned to find out what is making it fail.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 07-28-2005, 03:43 AM
I have gone to get the codes and almost every single code came up. Im not sure if maybe then computer was damaged, or maybe it short circuited. Ugh!! What a pain!
Old 07-29-2005, 10:07 PM
cutlasskenny's Avatar
cutlasskenny cutlasskenny is offline
what if the ABS light is on but no codes come up?
Old 07-29-2005, 10:32 PM
BlazerLT's Avatar
AF -Advisor
The codes will be there if they have the right scanner that accesses the ABS module.
Old 08-01-2005, 10:18 AM
Re: Re: 1995 blazer problems with brakes
I was reading on the AutoZone website under the troubleshooting section and I read that it might be the master cylinder and that it may need to be replaced. Also, the brake fluid is dark and dirty. Is it common to go and get brake fluid replaced? Are there any chain stores that can do it at low cost?
Old 08-01-2005, 03:23 PM
BlazerLT's Avatar
AF -Advisor
Most shops should be able to flush the braking system.
Old 08-01-2005, 05:26 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Most places can flush the general system, but for a proper flush they need to use a Tech 2 or similar to open the ABS valves (for newer systems, and a claw tool for older non electronic controlled ABS) so that the fluid in the ABS module will also be flushed out.
Old 08-02-2005, 06:37 PM
Re: Re: Re: 1995 blazer problems with brakes
I have just found a leak in the metal tubing brake line right under the truck on the drivers side inbewteen the 2 doors. As soon as the brake is depressed, fluid squirts out like a leak in a garden hose. Hopefully replacing the tubing will fix the brake problem. I also plan on replacing the fluid.
Old 08-03-2005, 12:31 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Re: 1995 blazer problems with brakes
You will have to bleed that system too.
