Go Back   Automotive Forums Car Chat > Dodge > SRT4
Old 03-28-2012, 08:52 AM
thunderchicken2 thunderchicken2 is offline
Odd rear tire wear
Ok, first off I want to say hello to everyone. First post in this section, and look forward to many more with you guys! Looks like you know your stuff here..
Have only owned the car for about 5k miles. 2004 SRT-4. 105k miles. Only thing aftermarket is solenoid delete, WG, HKS BOV, CAI, custom 3" exhaust, braided fuel lines and FPR, and SAFC-2 (I know, it needs to be gotten rid of).
Ok, i replaced the tires a little less than 3k miles ago. A full set of Nexen N5000 Ultra High Performance stock tire size. I recently noticed bad wearing of the rear tires, while the front two still look brand new. The tread on rear tires is approximately 50% in only 3k miles.. My first thought was alignment or over-inflation, but upon further inspection, it isn't uneven wear (all tires are checked routinely for proper inflation). Bad alignment wouldn't cause even wear could it? Both rear tires are worn EVEN all the way around, which is why it is so odd to me. Can anyone lead me in the right direction? Any help would be greatly appreciated, thank you all in advance!
The first is the front tires. Second is the rear.. And yes, I said only been driven 3k miles!
2004 Dodge SRT-4
- K&N Ram Air Intake
- AGP wg
- HKS SSQ BOV
- AEM UEGO wideband
- stock boost gauge
- Full 3" custom exhaust w/ Magnaflow muffler
- Rerouted vaccuum lines
Old 03-28-2012, 08:59 AM
Re: Odd rear tire wear
...And I just noticed that this should most likely be in the Problems section. If so, mods could you move the post please? Thank you!
2004 Dodge SRT-4
- AGP wg
- HKS SSQ BOV
- AEM UEGO wideband
- stock boost gauge
Old 03-28-2012, 09:45 AM
ricebike ricebike is offline
it's still under a 60,000 mile treadwear warranty... go to the tire shop and get some replacements using the mileage installed instead of the tread depth adjustments...
i'm suspecting rear brake calipers are hanging up and/or the parking brake mech in the back are not releasing all the way...
suggest lifting the vehicle and spin both rear wheels to see if they're hanging up or spinning freely with the parking brake off
after you ruled that out, from what i'm reading on other sites,
check for rear toe & thrust angle on the alignment rack (of course, get a printout)
The Following User Says Thank You to ricebike For This Useful Post:
thunderchicken2 (04-02-2012)
Old 03-28-2012, 11:02 AM
jamesslcx jamesslcx is offline
For that much even wear in that short of a time only on the rears, I say faulty tires.
Old 03-28-2012, 11:52 PM
i'm reading bad things about this south korean made tires...
jamesslcx (03-29-2012)
Old 03-29-2012, 01:31 PM
So have I ricebike, if the op statements are accurate something is really wrong and I have heard tales of the hit and miss quality of these tires.
Old 04-02-2012, 12:47 AM
Thanks to both of you.. I will definately get it lifted up tomorrow and do as you suggested ricebike. I had never heard of rear tires on a FWD car wearing so bad, especially after only a few miles. I was going to take the car back in to the tire shop and try and get some kind of replacement with manufacture warranty, but figured I would at least need an alignment printout before they would even think about doing something about it. The reviews I read before I bought the tires were all very positive, but going through now and reading again i'm finding more and more negative. I guess that's what I get for buying cheaper tires.. I will get back to you once I get the chance to mess with it. Again, thank you to you both.
2004 Dodge SRT-4
- AGP wg
- HKS SSQ BOV
- AEM UEGO wideband
- stock boost gauge
Old 04-02-2012, 12:18 PM
Nice car and good luck to you.
Odd wear on inside front drivers side tire tennesseeguy Sable 5 09-17-2011 01:38 PM
Tire wear overthehill10 Cars in General 1 05-21-2011 10:15 AM
olds 88 with uneven tire wear ryanusrey2012 Eighty Eight 1 05-09-2011 11:19 AM
Rear Tire wear please help! Flava888 Prelude 3 09-16-2004 02:28 PM
SL1 Rear Tires Wearing Out Quick jklutts SC/SL/SW 1 04-27-2004 12:18 AM
