Old 03-26-2012, 09:27 PM
carguyvr4 carguyvr4 is offline
Send a message via AIM to carguyvr4
ECU / Capacitor problem
So the 93 vr4 has been in the garage for awhile, replaced the battery & did an oil change. Go to start it... crank but nothing.. try again.. crank & start but dies... one more time it starts up & runs for about 5 min, sounds a bit off but its been sitting for a bit, adjust idle cuz it seems off... car stays running but then idle jumps about 3-4 times, hearing a clicking from behind the head unit, car shuts off... continues to do it each time the car starts but no certain time frame. I know about the capacitors going bad, i pulled it out it has a "fish smell" looks a bit ify. However there is a rectangle near each capacitor that is also blackened... can anyone tell me what those are & or for? Also does anyone know a how to or step by step to replace them, or a video or even anyone in the NE PA area who can fix them... its either that or buy a stand alone AEM
Thanks
Old 03-27-2012, 06:38 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: ECU / Capacitor problem
This should at least help you out. Found it in about 2 minutes searching on google.
http://www.vfaq.com/mods/wayback/caps.htm
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 05-25-2012, 09:38 PM
toddrs93's Avatar
toddrs93 toddrs93 is offline
for future reference we fix them, located in Hagerstown, MD. Its not always as simple as it looks, the board must be cleaned properly and all damage removed before installing new caps. I guarantee the repairs as well.
Auto Velocity
301-991-6501
P11 Turbo Diesel-ECU/Electrics Problems Rapalla Maintenance 12 07-14-2008 03:06 PM
ecu capacitors screeeech 3000GT/Stealth 17 04-19-2007 05:29 PM
ecu capacitor corrosion? Fiya3000GT 3000GT/Stealth 4 05-16-2005 09:04 PM
dohc zc ecu questions, 89 integra ecu any problems? OneSikCRX '88 - '91 Civic | CRX | Wagon | Shuttlee 2 09-22-2003 08:47 AM
