Old 04-17-2007, 02:30 PM
screeeech's Avatar
screeeech screeeech is offline
ecu capacitors
hello everyone. i was looking over ebay and i notivced that there is ecu capacitors for my car ( i drive a 1991 3000gt vr-4, 134k miles ) and i was wandering if this would be any good. i know that ebay sells alot of cheap stuff, but i heard sometimes it doesnt really matter. my question is should i get these capacitors or should i get the real thing.
p.s. i heard the capacitors is what causes my idol to mess up sometimes. every so often my car will idol at around 600 rpms or just turn off, and sometimes it will idol at 2000 rpms, but most times its normal at around 900-1000. any help would be appreciated
heres the link for the capacitors:
http://cgi.ebay.com/ebaymotors/3000G...08304275QQrdZ1
Old 04-17-2007, 06:27 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: ecu capacitors
Your screwy idle is most likely the cause of a faulty IAC.
Old 04-18-2007, 02:34 AM
screeeech's Avatar
Re: ecu capacitors
iac is idle air control right? im not sure if thats a big problem to fix, if it is expensive, hopefully cheap.
so i guess i dont need the capacitors.
what do the capacitors do? what happens when they go bad?
Old 04-18-2007, 02:38 AM
planet_keeper's Avatar
planet_keeper planet_keeper is offline
Re: ecu capacitors
i've heard that if a smell like fish sticks comes through your vents it can mean that your a capacitor in your ecu could be melting, which would mean very bad news for your ecu and worse news for your wallet (new ecus aren't cheap). im not positive on what preventative maintenance helps to stop this or if its even a good idea to change the capacitors prematurely though.
'93 black vr4, HKS boost controller and gauge, gutted pre-cats, 3sx downpipe, intake, 18" zenetti rims, tein-s springs
Old 04-18-2007, 02:45 AM
screeeech's Avatar
Re: ecu capacitors
ill try to research it, or if anyone knows, just let me know. oh and i havent smelled like fish sticks yet, so i guess thats a good thing.
Old 04-18-2007, 09:30 AM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: ecu capacitors
$281.29 for the iac at 20% off factory list price (this is for a mitsubishi part)
Old 04-18-2007, 11:26 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: ecu capacitors
Try cleaning the IAC first, sometimes it just gets dirty. It's a common problem. If it's the the ECU, and easy way to check it to open up the ECU and look around the base of the caps. If they have leaked then they will have discolored the PCB around them. Some of them also bloat and burst. You will know if they have leaked by looking at the ECU. If not take a pic and post it up and we can tell you if they've leaked.
Old 04-18-2007, 12:51 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: ecu capacitors
aww, that's cute, a dealer trying to compete with non-dealer prices.
www.dsmisc.com IAC~$132
www.thepartsbin.com IAC~$185
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 04-18-2007, 01:25 PM
Hotshot8792 Hotshot8792 is offline
Re: ecu capacitors
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 04-18-2007, 01:57 PM
jason_bet's Avatar
Re: ecu capacitors
oh yeah.. I will sell you mine for $25 brand new!! factory part!!
ok.. no i wont.. haha
I sware some people are freaking crazy.. like this guy came in two days ago and ordered a factory cd player! it was Fing 1200 bucks! for pos galant! but what ever turns your tacos.
Old 04-18-2007, 02:24 PM
Linebckr49's Avatar
Re: ecu capacitors
yup, some ppl ARE crazy. you know why? b/c they are stupid and/or have too much money. take Nelson Bernardes, for example.
the real question is how much of a markup is the "factory list price" from the price of cost ???
93 3000GT base
Old 04-18-2007, 02:35 PM
jason_bet's Avatar
Re: ecu capacitors
I put 20% but i ment 25% anyways I would get my ass ripped if i say dealer cost.. but the cost is much higher then the after market ones..
Old 04-18-2007, 03:15 PM
Linebckr49's Avatar
Re: ecu capacitors
the links i listed aren't aftermarket IACs, they are OEM IACs direct from the company that makes them for Mitsubishi.
93 3000GT base
Old 04-18-2007, 03:35 PM
screeeech's Avatar
Re: ecu capacitors
does anyone have a good link on how to clean an iac?
Old 04-18-2007, 03:44 PM
Polygon's Avatar
The Red Baron
Re: ecu capacitors
Here you go:
http://www.stealth316.com/2-isc-iac.htm
