Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 03-24-2012, 03:02 PM
SilverStarr1 SilverStarr1 is offline
Angry 1996 Mercury Grand Marquis, fluid in crankcase
While driving my car I noticed my temp gauge was above normal and climbing when I stopped and checked the overflow it was empty I filled it back up I did not see any leaks anywhere I drove my car through neighborhood short distance returned home checked the overflow again and once again it was very low. I pulled the dip stick and there is visably fluid from the radiator in the crankcase. I find no indications of any visable leaks my car starts properly and runs smoothly, anyone have any suggestions on where my next step in determining what is causing this problem, my car has never severely overheated, no smoke or moisture out the tailpipe?
Old 03-25-2012, 02:38 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 1996 Mercury Grand Marquis, fluid in crankcase
It is either a freeze plug or a head gasket failure. My money would be on the freeze plug if the engine did infact never overheat. Stop driving it until it is fixed and you have flushed the crankcase of all coolant contaminants. There are abrasives in there and they WILL destroy your bearings.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 03-25-2012, 04:35 PM
tempfixit tempfixit is offline
I would do a clyinder leak down test to see if you have blown head or intake gasket. You could also try a coolant system pressure test to see if you can located a external leak. WHen you have the coolant resorvoir to correct level do you see bubbles in the coolant while engine was running.
Like Blue Fussion mentioned do not drive as the anti-freeze will destry the bearings.
1987 Mercury Grand Marquis transmission filter change and draining the trans fluid Johnobub Grand Marquis 2 11-24-2009 12:07 AM
1996 Mercury Grand Marquis temperature gauge inoperative moman406 Grand Marquis 1 02-27-2006 02:41 PM
Best Year for the Mercury Grand Marquis? 87MercMan Grand Marquis 8 02-26-2006 11:19 AM
1987 Mercury Grand Marquis Engine Swap 87MercMan Grand Marquis 6 04-05-2004 12:42 PM
1975 MERCURY GRAND MARQUIS Question Batman_0503 Grand Marquis 0 07-12-2003 08:55 PM
