Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 10-19-2009, 12:27 PM
Johnobub Johnobub is offline
1987 Mercury Grand Marquis transmission filter change and draining the trans fluid
I'm preparing to change the transmission filter on my 1987 Mercury Grand Marquis AOD transmission. I'd like to know what is the amount of trans fluid that will come out. If the transmission fluid level is full when the transmission pan is removed, how much transmission fluid should I expect to drain out before fluid stops draining? Also, after loosening one end of the pan, does a lot of fluid drain out at one time when it first starts draining or should I expect slow draining?
Old 10-19-2009, 03:52 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 1987 Mercury Grand Marquis transmission filter change and draining the trans flui
If you are just draining the pan and changing the filter, expect to need about 4 to 5quarts. If the pan comed down quickly, thyere will be a lot of fluid come out. If you can lower the pan real slowly, you can control the flow. Just use a large diameter pan.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 11-24-2009, 12:07 AM
I have changed the fluid after removing the pan however I'm not done with the job. I ordered a 1/4" torque wrench to make sure I'm not over tightening the bolts of the filter and the pan. I have not driven the car but did notice it took 3 quarts of trans fluid after I removed the pan and filter. I filled it up the mark for room temperature and left it at that before driving it. I will keep all those interested updated of what happens next. By the way, I suspect the trans is bad on the car because of the facts it was shifting wierd.
