Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 03-24-2012, 04:00 PM
chevyrulespops's Avatar
chevyrulespops chevyrulespops is offline
RamJet 350 Fuel Injectors Not Firing
I was cruising down the highway and the car just died. It cranks fine and all the wires are intact and the ground cables are connected properly. I am almost positive that the ECM might have a problem in the quad driver or the swtich to turn on the the injectors. There's plenty of spark at various spark plugs and plenty of fuel reaching the manifold. I am looking at the prices for these computers and they are not cheap at 500.00 and up. So I just wanted to double check just to make sure that I am not overlooking something. I didn't change the steel exhaust manifolds and they generate a ton of heat and where the computer mounts on a steel plate I guess is not the smartest place to locate this unit. I only have a little over a thousand miles on the engine so I doubt any relays went bad. All fuses are good! Any one have any suggestions??
I also read from someone elses post that all of the injector connectors have to be removed in order to test with a noid light. I only checked with one off at a time. When we spray the throttle area with starter fluid, it will start right up.
Fuel Injector Signal S Wrap Frontier | Navara 0 08-28-2011 06:01 PM
Trying to find the Fuel Injector CyborgGold Celebrity 7 06-11-2011 07:49 AM
help! fuel injector problem Suzannes Caravan | Voyager 9 11-07-2009 02:06 PM
fuel injectors not firing atcman86 Sierra 1 08-03-2009 01:10 PM
'89 Dodge Ram Van B350 1-ton: Fuel Injector Not Firing littledodge1 Ram Van 4 10-25-2008 08:41 PM
