Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 08-02-2009, 08:57 PM
atcman86 atcman86 is offline
fuel injectors not firing
I have an 89 gmc 1500. The fuel injectors will not fire. I have power going to the injectors. They will fire when I ground them. I have replaced the ecm, and checked the wires going from the ecm to the injectors and they are good. Is there a fuel injector relay, crank sensor? Does this truck have a keypass system? The injectors do fire once every now and then when you try to start the engine. No codes when hooked to a computer. Thanks for any help.
Old 08-03-2009, 12:10 PM
maxwedge maxwedge is offline
A990 racer
Re: fuel injectors not firing
Replace the ign module in the dist and check the wiring, look closely at the pick up also..
