Go Back   Automotive Forums Car Chat > Nissan > Frontier | Navara
Old 08-28-2011, 05:01 PM
S Wrap S Wrap is offline
Fuel Injector Signal
Hi all you experts,
Here's my problem: 2000 Frontier XE 4cyl. automatic. Vehicle starts and runs, but number one cylinder is not firing. Through considerable troubleshooting I have determined its not the injector, compression, spark. It's the signal.
I confirmed this with a Noid light. The test revealed that the injector is receiving power all the time and apparently not receiving the ground interrupt signal from the ECM. Again it is only the number one cylinder. So, where do I go from here? Is it the ECM, or some other signal or short that could be the problem?
Thanks for you help!!
fuel injector cleaner RidingOnRailz Engineering/ Technical 8 07-04-2011 06:46 PM
Trying to find the Fuel Injector CyborgGold Celebrity 7 06-11-2011 06:49 AM
help! fuel injector problem Suzannes Caravan | Voyager 9 11-07-2009 01:06 PM
91 4.3 Injectors Will Not Pulse chaddeaton Problem Diagnosis 1 03-10-2009 05:33 PM
95 Villager Code 51 fuel injector signal fault wade12345 Villager 6 07-30-2006 10:20 PM
Tags
ecm , firing , fuel , injector , noid
