Old 03-22-2012, 10:59 AM
reid1717 reid1717 is offline
Smile 97 olds bravada
random misfire and trans slipping i replaced all fluids trans filter and replaced all intake gaskets now it wont run rite and trans wont shift properly HELP PLEASE
Old 03-22-2012, 08:04 PM
old_master's Avatar
Advisor/Moderator
Re: 97 olds bravada
Diagnostic trouble codes, (DTC's) must be diagnosed and repaired starting with the first one that is retrieved. All DTC's must then be cleared and a drive cycle performed to confirm the repair. If the service engine soon, (SES) light comes on before, during or after the drive cycle, the process is then repeated until the SES light remains off. The first DTC that is retrieved can set other DTC's, that's why the first one needs to be repaired before continuing.
What DTC's did you retrieve and in what order?
The ignition switch is a very common problem on your 1997. When it goes haywire, it can cause all sorts of driveability issues and set false DTC's. Has it ever been replaced?
Have you checked the fuel filter for restriction?
Have you checked fuel pressure and leakdown? If so, what were the results?
You have to know how it works,
to figure out why it doesn't.
96 bravada shifter issue nassaudaddy53 Problem Diagnosis 0 07-17-2010 10:09 AM
Possible short-electrical problems? Olds Bravada 43000 miles! DeniseHarrold General Discussion 3 10-10-2005 09:25 AM
2002 Olds Bravada njyahoo Bravada 2 11-22-2004 03:33 AM
2002 Olds Bravada Remote jivaro General Discussion 2 12-30-2002 08:56 AM
programming keyless remote for 1993 Olds Bravada fergus General Discussion 1 11-08-2002 08:03 PM
