Go Back   Automotive Forums Car Chat > Kia > Sportage
Old 03-21-2012, 08:05 AM
H1LL27 H1LL27 is offline
Starting problem with '99 Kia Sportage
Hello,
I recently purchased a used 1999 Kia Sportage 4WD automatic, and I am all of a sudden having problems getting it to start. When I turn the key, the radio & dash lights come on but the car doesn't (not even a clicking noise). However, when my BF gets on the ground and under the car to wiggle a wire, car will start right away. If the car does not start immediately, I found that keeping the key turned for a few seconds will automatically bring life to the car. Please help. Would love to not have this problem.
Old 04-07-2012, 10:26 AM
LMP's Avatar
LMP LMP is offline
Re: Starting problem with '99 Kia Sportage
I'd suspect the transmission neutral/park switch....it allows starting only in these positions...wire/plug/switch failure would explain your problem.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 02-14-2013, 07:47 AM
Jliberman Jliberman is offline
2002 Kia hard to start
This Kia was brought to me because it was over heated. I replaced the head gasket and the head was sent out and was resurfased. Now when I trie to start it I have to crank and crank it over and keep the throttle to the floor when it finally starts it sounds pretty good. I have 50psi of fuel press when cranking. I have no codes in the computer. I do have low compression 1-95. 2- 50. 3-50. 4-125. But when it's running this engine sounds good I would give it to my couctomer if it didn't have this starting problem. Any help would be appreaited.
Old 02-17-2013, 10:06 PM
LMP's Avatar
LMP LMP is offline
First thought is about cam timing....can you confirm this issue is totally 100% sure?....
Old 02-24-2013, 04:03 PM
Timeing is dead on. Compression is still low. Dissasembeld and found valves not sealing. Sent head back to machine shop. Removed pistons and checked rings. I see no problems with them. I'll recheck after I get it back together. Any tips are appreaited.
fuse problems on my KIA Sportage 2001 vik1977 Sportage 13 12-01-2012 08:31 PM
2000 Kia Sportage died on fwy. Will Turn over but not start...HELP over_kia Sportage 3 10-16-2010 02:11 AM
Where is the fuel filter on '99 KIA Sportage? PLEASE HELP!! Graf024 Sportage 1 08-24-2009 11:28 PM
A/c Problems With 97 Kia Sportage guynftl Sportage 2 06-09-2005 10:20 PM
I Need Professional Help With My Kia Sportage RACE43 Sportage 5 05-28-2004 06:31 PM
