Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 03-18-2012, 12:24 PM
malibumlk malibumlk is offline
Did I fry my ECU !!?? Help please.
'01 3.0i auto;
This morning I was trying ton confioirm Peak code 7b (Thermostat map control) which as I understand, is related too the heating element of the main Thermostat (2 prong connector on top, just behind the top of the fan blade).
To check that I was getting power to the plug/heater element, I connected my volt meter to the 2 prongs in the plug/harness side and turned the key on while watching. The meter bleeped a bit but nothing, so I dicided to start the engine and see if that would bring the power up. No start.
It turns over but wouldn't start. Replugged the connetor - same. Checked all related fuses - OK. Disconnected the battery for an hour - same.
Any help on something like this??
THANKS IN ADVANCE!!
Worried
Old 03-13-2013, 02:32 AM
Victor520 Victor520 is offline
Re: Did I fry my ECU !!?? Help please.
you need a ecu tools and you can find some good ones in xcardiag.com
i had buy some from it and they are cheap and good
where there is a will there is a way
just a blog
Old 10-10-2013, 07:01 PM
dannydoo dannydoo is offline
I broke that sensor off in the housing and its been dangling in its clip for 7 years.
Check f or other plugs you 4got to plug in.
Help please...Screwed up replacing CPS, did I ruin the distributor also? ksubenny Problem Diagnosis 8 10-10-2008 08:15 AM
P0171 Code Need Some Help Please. I did search first! alfieferenzo84 Grand Prix 17 04-10-2007 08:32 PM
Newbie! a turbo and your ECU? any help please? Killa_CRX Forced Induction 1 06-18-2003 11:39 PM
ECU problem???? Please Help tootall_paul Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 10-27-2002 08:04 PM
5th gen ECU/air-fuel gauge Help PLEASE!!!!! big blue h22 Prelude 2 01-07-2002 05:19 PM
