Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-18-2003, 12:36 AM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
Question Newbie! a turbo and your ECU? any help please?
I'm considering getting a turbocharger for my car, and I'm curious as to the affects a turbo has on your cars ECU and what can be done to get around any problems it may cause.
I have a 98 Civic EX by the way, incase that helps any.
Also, I've heard a lot about changing out your engines internals before turbocharging. and I was wondering... exactly what parts should be changed in order to keep the car a steady reliable daily driver? (Planning on going with the Revhard Stage 2 kit by the way)
Honda Enthusiast
Old 06-18-2003, 11:39 PM
neunan neunan is offline
Send a message via AIM to neunan
try to grab a backissue of sport compact car that deals with turbos and prepping your car. im sure somebody has links to websites that would help too, but i dont have any atm. 98 civic ex, is that a d16 of some kind? anyway, i highly doubt that engine can take a lot of boost. if youre running like 5-7 psi you might be able to leave the internals alone, and only upgrade the standard things like exhaust manifold, fuel injectors...all the stuff that comes in a kit basically. and thats only a maybe.
re: the ECU, i think it either needs to be reprogrammed or overridden. but im kinda new to FI as well so ill wait for somebody more knowledgable to post
re: changing the internals, i think a lot of that is done to lower the compression ratio. otherwise to strengthen whats there to withstand the increase in pressure FI is going to cause. forged pistons, reinforced sleeves, stronger rocker arms, closing the head, etc.
96 Accord EX 5spd coupe - black
AEM cai * DC Sports cc 4-2-1 header * GReddy EVO catback* AEM trupower pullies * ACT HDSS clutch kit * ClutchMasters 8lb flywheel * NGK blue wires * 4 wheel Brembo slotted rotors with AEM pads * 4bidden Motorsports shortshifter
pioneer deh9300 * phoenix gold zero point wiring * blaupunkt pa2100 pushing diamond audio HEX 6.5 comps in front * blaupunkt pa275 pushing power acoustik fahrenheit 6x9s in back* 5" LCD TV * 8-bit original NES
Starter and/or Electrical issue??...Need your input & help PLEASE! Viol8tor Aurora 4 03-29-2005 12:57 AM
High Idle 2,000 rpms to 4,000 rpms any help please NJH_Habitatpro Neon | Plymouth Neon 2 02-18-2005 12:05 AM
ECU code help please ziya20 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 08-26-2004 11:28 AM
B16 dizzy & ecu any help for d16z6?? QuikShifter '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 06-04-2004 09:58 PM
WTB: 99-00 Bomex Alligator front ANY HELP PLEASE!!! VTEC_boi Exterior | bodykits | Lighting 1 02-02-2002 04:39 PM
