Old 03-17-2012, 04:35 PM
Tamm85 Tamm85 is offline
Jaguar E-Type Revell 1/25
Got this for cristmas
Its revells reissued kit, first it was made 1963 and again 2011, molds are from 63 so its not very good quality,needs alot sanding etc, but quite detailed,126 parts
And progress so far
painted today, motip swartch black
Interior painted with tamiya paints
Old 03-24-2012, 05:25 AM
Re: Jaguar E-Type Revell 1/25
Thanks
Cleared it with 2K, mixed the clear littel bit diifferent then i use to and result was no orange peel effect
But..... i accidentally left it too near to halogen lamp, moment after it was allready twisted
Trying to get it back straight with heating so i dont have to repaint it but its too hard
Old 03-24-2012, 06:29 AM
euro_z's Avatar
euro_z euro_z is offline
that paint is fantastic! whata shame about that warp though!hope you can get it straight again
Old 03-24-2012, 05:12 PM
Thanks ! Sent email to revell hope to get new hood
Some work done today
Old 03-24-2012, 06:17 PM
Some work with epo putty, sanded it down and yeaah it fitted nicely :-P
Some more work with putty and it will be like new 8)
Old 03-24-2012, 07:34 PM
Moparbuilder Moparbuilder is offline
What did you do different with your clear coat that you didn't get orange peel with 2K? I always have to polish mine because of waves in the clear. More reducer, more hardener?
Old 03-25-2012, 07:34 AM
DominiqueBeerts's Avatar
DominiqueBeerts DominiqueBeerts is offline
If your clear coat ends up with waves, then it looks like you may have three possible problems:
1. the lacquer is too thin. When spraying the lacquer it does not stick to the surface, it flows over it. Either the lacquer needs to be a little bit thicker, or you spray with too much pressure.
2. the clear coat is too thick. Build up your clear coats just like you build up your paint layers: in multiple thin layers until you have a solid base, then apply a slightly heavier coat as a last "wet" coat. Underlying layers allow the above coat to "glue" onto the surface.
3. as said in the first remark: too much air pressure. If above remarks are met, then try to lower the pressure a little bit, or spray from a larger distance.
It may well be that you do some things exactly the way they need to be done, but do something wrong on another. Therefore it is difficult to pin-point the real problem from distance. Try out different things so you can eliminate possible causes. In the end you will find the exact problem as you go.
Succes!
Best regards,
Dominique.
Feel free to browse through my photo albums
Old 03-25-2012, 03:41 PM
Hood painted and cleared
Undercarriage
Finished: Revell 1/25 Jaguar E-Type Roadster hirofkd Completed Projects / Gallery 29 12-28-2013 08:03 PM
Revell 1/25 ITR vs Fujimi 1/24 ITR SOLOITR2001 Car Modeling 4 09-29-2010 08:48 PM
Revell 1/25 E-Type Jaguar - a Classic British Kit mattbacon Completed Projects / Gallery 8 08-27-2010 10:55 AM
Revell 1/25 Dodge Viper SRT-10 (FINISHED) stormer_GS Completed Projects / Gallery 8 10-29-2007 02:55 PM
Jaguar E-type (XKE) 1/8 Revell Erik O. WIP - Street 9 08-18-2007 08:06 AM
