Old 03-17-2012, 02:36 PM
kennethb80 kennethb80 is offline
question about 01 blazer lower intake manifold
I have an 01 chevy blazer...the mechanic said that the head gasket was gone after doing a pressure test on the coolant. I pulled off the intake manifold and found that one of the water ports was clogged. My question is should I go farther and check the head gasket of just clean up the water ports and reassemble
Old 03-17-2012, 06:14 PM
Mx5guy Mx5guy is offline
Send a message via AIM to Mx5guy Send a message via Yahoo to Mx5guy
Re: question about 01 blazer lower intake manifold
Hey Ken in this case I would go and get a second opinion, If the system lost pressure during the test something is wrong for sure but what motivated u to have this mechanic check your car, what were the signs?
Old 03-17-2012, 06:39 PM
FishFind FishFind is offline
One Hot Shot
I would not use that test to say you have a bad head. It could be leaking from many areas other then the heads. You need a compression test to tell if it is your heads. You can rent the tool for less then $30 and get a refund when you take it back to autozone.
Check you oil filler tube for anything that does not look correct. Most of the time your oil will look like a milkshake with a bad head.
If you took off the valve covers what did it look like under there?
Lower Intake Manifold Gaskets Failure Question drzoidberg Windstar 10 11-29-2008 10:27 AM
Lower Intake Manifold Replacement Questions sarotara Park Avenue 5 08-19-2008 05:28 PM
Help 97 Blazer..Changed lower intake manifold gasket Spit Problem Diagnosis 4 02-04-2008 08:10 AM
Lower intake manifold question windsour Windstar 2 01-25-2006 10:11 PM
lower intake manifold question mattpiper Grand AM 11 08-28-2005 04:28 PM
Tags
coolant , intake , oil
