Old 08-27-2005, 07:41 PM
mattpiper mattpiper is offline
lower intake manifold question
i'll start by saying thanksto the peoplewhohelpedme determine that the LIM is my problem. i got a shop manual today and i am a little confused. are there 2 intake manifolds (upper and lower) or are we talking about the lower gasket on 1 manifold that is giving me the problem.
Old 08-27-2005, 08:01 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: lower intake manifold question
Hey Mattpiper. Ya, there are two peices on the intake. the bottom one, that sits on the Heads and the block is (hopefully) where the leaks usually happen. it either leaks in the oil, or in to the exhaust ,which the later is better than in the oil.
You may even want to change the oil when ur done to be certain the oils not contaminated. other wise it can mess up the bearings in the motor,not good, very bad :evil: Hope this clarifys. anything else let us know. \,,/
Old 08-27-2005, 08:05 PM
thanks, soonemanmifol, two pieces. by the way it is 93 grand am quad 4, 53,000 miles.water is in oil and also dripping under the car.
Old 08-27-2005, 08:25 PM
OK Wrong caar.LOL! there is just one intake manifold on the quad 4. it might have a left and right half, but i'm pretty sure it just one. up above u said "upper and lower", so I assumed u ment the V6. I remember from the other post now, duh.
The v6 has two peiced intake, which blow out often.damn reliability. LOL! If you have the manual you should be able to tackle this. If u havnt done this before I'd read through it once or twice before taring down. Just take ur time, you may even use tape on wires/plugs so its easy to get Hooked Up and running. Hope this clarifies things.
Old 08-27-2005, 08:34 PM
so is the manifold a probable cause on the quad also for water in oil and leaking out also
Old 08-27-2005, 08:56 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
It sounds like the evil head gasket or a cracked head, but with only 53k miles something is suspicious. I recently changed the head and gasket on my 95 quad with 240k miles. Changing a head gasket on a quad is not an overly difficult job, just time consuming and messy. It's also not a job you want to do in your back yard as you probably won't finish it the same day you started it. I started mine at 10am, quit at 8pm, and it took 2 hours the next day to finish it, but it was also 95 out and very humid. If you do end up changing the head gasket, change your timing chain, tensioner and guides as you have to take all that off anyway. Good luck, not trying to discourage you, just want you to be aware of what you are in for....
Old 08-28-2005, 09:21 AM
Re: Re: lower intake manifold question
Water in the oil on the Quad.. Probley is the head gasket. Just as skibum said, its a time consuming job with lots of things to remember and disasemble. But dont be discouraged. Just refer to the manual, its ur friend. Good Luck
Old 08-28-2005, 09:35 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Back the truck up here!!!!!!!!!
To get the correct information about repairs, you must give us ALL the information so we can give you the CORRECT repair information
So you have a quad 4 engine with water in the oil..well that is a whole different senerio..Those engines are known to blow head gaskets and crack heads.
You have some serious problems, but the good news is "I saved a bunch on car insurance by switching to Gieco"
Seriously, it can be fixed, you will have to send the head off to a machine shop and have it checked for cracks.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 08-28-2005, 10:08 AM
GMMerlin those heads are aluminum? on a steel block.
Old 08-28-2005, 10:50 AM
GMMerlin's Avatar
I know stuff
They sure are.
GM WCT
PM Me for details
Old 08-28-2005, 11:02 AM
that isnt the smartest idea. aluim heats up ten times quicker that steal. with all the expantion and contracting its no wonder they blow. But it is common on todays cars. Sorie of thread here. later!
Old 08-28-2005, 04:28 PM
once again thanks everyone for your help...much appreciated.
