Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 03-14-2012, 08:22 PM
amad20003 amad20003 is offline
2001 chevy tahoe idles rough!! please help
I have a 2001 chevy tahoe lt...it has a rough idle...and also doesnt respond when i punch the accelerator...what should i do....i have replace the fuel pump....i have already clean out the tb...i have replace the fuel regulator...now my mechanic says that it is a bad intake gasket...can that be posible...or should i cleab the MAF first to see it that is it...please help i know i that alot of chevy tahoe owner have this problem and its frustrating....we take it to one and they say one thing we take to another and they say another..thanks for view and any commwnt would be greatly appreciated...
Old 03-15-2012, 08:47 AM
maxwedge maxwedge is offline
A990 racer
Re: 2001 chevy tahoe idles rough!! please help
Welcome to AF, in the future post in the Tahoe/truck forum below. Rough idle can be caused by many things, ign misfire, bad injector, vacuum leaks. someone on site has to pin down the cause and/or scan for codes. Normally the maf would not cause this.
Old 03-15-2012, 07:05 PM
j cAT j cAT is offline
first thing to do is measure fuel pressure with a pressure guage and do the pressure test proceedure.
pull all failure DTC codes and post all this info here before spending any more $$$$.
for your info these vehicles do not have idle issues.
how often do you replace the fuel filter/use injector cleaner ?
when did you last replace the PCV ? check these crankcase hoses as well.
could be you have bad, old, water, in the fuel.
a dirty MAF will cause slow throttle response NOT rough idle. what is the idle rpm ? should be 600rpm in or out of gear !
Old 03-16-2012, 12:24 AM
My truck doesnt reapond when i step on the gas peddal and it also
Idles rough and its below 600 rpm....i thinks its somewere 450 to 500... My mechanic said that it could be the intake gasket....i hava already fixed the misfire and also changed both cats already....fuel pump also has been replace.... Three of the eight fuel injector have also been replaced....i dont know what to do.....gave me something else please thanks. .
Old 03-16-2012, 12:28 AM
But doent the maf causea the truck to take about 5 seconds for the throattle to repond....
I have already fixed the misfire...its 3 of my fuel injectors...and i also replaced my cats alreadyand also my fuel pump....
CAN IT BE MY INTAKE GASKET.....OR SHOULD I TRY CLEANING THE MAF FIRST...TO SEE ID IT FIXES MY TRUCKS THROATTLE HASSITATION....THANKS FOR UR HELP...
Old 03-16-2012, 07:52 AM
with your info now I would find a better repairer. this guy is an idiot or crook bleeding your wallet. do as I mentioned earlier. Get data do testing then this can be repaired.
Tahoe idles rough when i hit a stop light... Luis83 Tahoe 2 07-16-2008 07:28 PM
2001 chevy tahoe stalling in low speeds??? psanchez Tahoe 17 11-02-2006 08:38 PM
1996 accord idling rough please help! marsul83 Accord/TSX/Accord Hybrid 2 07-15-2006 09:54 AM
99 Passat idles rough -- Please help artmann '97+ 2 08-26-2004 12:30 PM
2001 Chevy Tahoe LS Starting problems kwscls C/K 2 12-26-2003 09:19 PM
