Old 03-13-2012, 12:45 AM
raymarquise raymarquise is offline
Smile 94 Voyager-Cigarette Lighter not working
The Cigarette Lighter on my 1994 Plymouth Voyager is not working. Tried a phone charger and GPS but they too did not work - I think there is no power at the socket. I checked the fuse box under the dash, but all the fuses are OK. Searched the forum, and it seems there is another fuse box under the hood - a power distribution center, but I cannot find it. Also, from the forum, someone says that the parking lights and the horn work from the same fuse as the lighter, but I have no problems with either of these. Maybe I need to change the lighter socket - but have no idea how to do that, although I have seen them selling online.
Any help in finding the fuse in the power distribution center and/or detailed instructions on how to remove and replace the lighter socket would be greatly appreciated.
Thanks in advance.
Old 03-15-2012, 03:21 PM
jamesslcx jamesslcx is offline
Re: 94 Voyager-Cigarette Lighter not working
Ray if memory serves the fusebox is right behind the battery. Anyway have you checked the wiring to the lighter? If all is o.k. you may have to replace the socket which isn't very hard.
Old 03-15-2012, 08:42 PM
Thanks for replying.
To check the wiring I will have to take out the lighter socket - can you give me some guidance on how to do that?
Old 03-19-2012, 11:38 AM
I found the labels for the fuse box under the dash, and one of the fuses is for the lighter - but, it is OK, anyways I changed it just to be sure - but the lighter still does not work. I also found the fuse box under the hood, behind the battery, but the label does not indicate that any of the fuses is for the lighter. They all seem to be fine. I now need to check the wiring to the lighter socket. I need help in how to get the socket out.
Thanks for all help.
Old 03-19-2012, 08:18 PM
Ray, I am not too familiar with your van but I think you can remove the panel around the radio, lighter, heat controls etc and it will help you see how to remove the lighter socket. It may unscrew or have clips or screws that hold it in you will know more when you pop the faceplate off, just go easy and don't break anything. Sorry I haven't got back to you sooner but I've been really busy. Let me know how it goes.
Cigarette lighter not working-92 Lumina delicatedelinquent Lumina 1 03-28-2006 02:02 PM
Cigarette Lighter not working soloscott Camry/Camry Hybrid/Vista 3 01-27-2006 02:04 PM
cigarette lighter not working a23m2000 Corsica 0 01-22-2006 06:13 PM
Cigarette lighter not working '96 4Runner karbine 4Runner/GX470 7 01-20-2005 02:17 AM
01 silverado - cigarette lighter not working JJAndry Silverado 6 11-28-2004 06:42 PM
Tags
1994 , fuse , lighter , voyager
