Old 03-12-2012, 03:33 PM
p71Interceptor p71Interceptor is offline
86 camaro check engine light flashes
hi i got a 1986 Camaro 5 speed 350 4 barrel carb and the check engine light flashes on and off, when it comes on the engine idles really low and when it goes off it runs normal. I've changed the ignition control module twice already because it wouldn't start. i change the ignition coil because thought that was messing the module up. any idea what problem is? and i hooked a obd ll and 1scanner too the car but wouldn't respond.
Old 03-12-2012, 06:44 PM
j cAT j cAT is offline
Re: 86 camaro check engine light flashes
GM F body camaro with the 4barrel carb was a 305 cu engine.
the IROC did come with the TPI 350cu engine.
to repair these issues you must find out how they hacked this engine into this vehicle with the electrical/emission system to work with the computer/pcm . good luck.
I would try to find a shop that does this type of modification work to get repair solutions.
my guess this is a pre 1982 4 barrel carb 350cu engine and they bypassed the computer system in some way.
what is the vin# 8th digit ? H or G would be the 305cu engine.
Old 03-13-2012, 02:01 PM
The Vin numba is a H. the car is a z28 it had the original 305 engine when we bought it like 10 yrs ago we bought the 350 engine from chevy dealership beacuse the 305 is discontinued the motor seized up or something so we just replaced it. but the car has passed smog. this check engine light thing just started happening now before changing the module it was really really bad but know after changing the module and the ignition coil it still does the chugging and lack of power but not as much. chugging is when the light comes on and when it goes off. its been 3yrs now with the 350 motor
Old 03-13-2012, 02:56 PM
maxwedge maxwedge is offline
A990 racer
If you have the oe ecu hook ups and sensors, you should be able to get a code from the ecu, jump the a and b terminals in the diagnostic under the dash. The lite will flash, count the flash sequences and post back.
Old 03-13-2012, 06:53 PM
as mentioned the code retrieval is what is best so try to get something out .
I'm gonna guess that the EGR may be bad. usually these get weak springs as they age and stay open too long /open too soon/too much.
this then causes the intemittent chugging..
remove the EGR and place a plate over the opening with a gasket to seal the two holes ..plug the vac line see if it still chugs..
If the cat converter is getting restricted this increases back pressure then you get too much EGR exhaust gases into the combuston chamber causing this as well.
make sure that the exhaust heat riser is not stuck and it is working or made to stay open all the time.
Old 03-14-2012, 06:27 PM
i did the paper clip test and it went like this engine light flashed one time pause then two times pause then one time pause then two times pause then one time pause then two times pause then it flashed two times pause then one time pause then two times pause then one time pause then two times pause then one time. I'm thinking how ever number of times it flashes befo the pauses that is the first numba then how ever number it flashes after the pause is the second number? so the first number is a 12 and the second is a 21 right?
Old 03-14-2012, 06:36 PM
also the battery doesn't stay charged like when i have the headlights on and the radio i cant go over a certain volume or the radio will turn off. and when i have the fog lights on with the headlights the radio sometimes doesn't even come on i have to turn off the fog lights. also if i don't start the car for two days the battery is sometimes dead or has a slow start like the belts are barely moving i have been thru 5 new batteries and two alternators so i have to start the car up every day. could this be a wire thing or sensors?
Old 03-14-2012, 06:43 PM
code 12 is no tach signal . with the engine off this is normal. code 21 is the throttle position switch open/ shorted so check the wires to the carb.
hook up a vacuum guage to the intake manifold. at idle the vac should be 17-21 inches. place a long vac line on the guage and place in the vehicle go for a drive and monitor the vac operation . then post what you saw.
Old 03-14-2012, 06:48 PM
this is most times a fuseable link going bad. these are wire fuses in the loom engine/starter wiring harness. when these go they slowly increase in resistance then you get a power/voltage drop to the operating elkectrical devices. if the voltage to the computer /distributor is not the full 12volts when running you will get a poor spark and loss of power. also a very poor burn/MPG.
Old 03-14-2012, 06:57 PM
would i be able to change these fusable links?
Old 03-15-2012, 08:11 AM
Sure , you cut them out . solder in new , place heat shrink tubing over these and the solder joints . now you have a sealed link. the wire size determinines what link you buy.
Old 03-17-2012, 07:05 PM
can i adjust the tps or get a voltage reading from a multimeter? how would i change the TPS its in the carburetor?
Old 03-18-2012, 08:43 AM
NO ADJUSTMENTS UNTIL THE ELECTRICAL PROBLEM IS CORRECTED.
This is an old long past problem even the pro's do. make carb adjustments when the engine has electrical or vacuum issues. not good repair technic.
Old 03-18-2012, 08:47 AM
I gave some ideas troubleshooting for you to check out so far no data from you . you have no tools ?
Old 03-21-2012, 03:27 PM
mybad the car got broken into and the took radio and smashed the window so car is parked in garage its been raining a lot so haven't been driving it. so far I've got a code 21
98 olds check engine light flashing & engine sputter oldsowner718 Intrigue 6 01-01-2009 11:11 PM
check engine light flashes over 55 mph 88_f150_300_4x4 F Series 5 02-20-2005 03:17 AM
stutter w check engine light flashing igbe Malibu 5 03-29-2004 10:22 AM
knocking sound on uphills / check engine light flashes serena Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 01-02-2004 02:02 PM
check engine light flash serally General 1 05-05-2003 08:38 PM
