Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-10-2012, 11:50 AM
InsaneCries InsaneCries is offline
Post 95 Eclipse GS-T Firing problem
I just got my 95 eclipse from a middle aged women who's ex boyfriend had it. She sold it because of the timing belt and the catalytic converter. I replaced the timing belt and lined everything up like my haynes manual says, I also detached the catalytic converter once I did that it started and ran rough. With my fathers help we figured out that only the #3 piston is firing even though all of them have spark. The car does run on the #3 piston alone so I know my timing must be right. Of course the engine cannot idle and it stalls when you let go of the gas I am only 16 and my father and I have been at this for 3 days so help would be appreciated.
File Type: jpg 5Lb5I75P43M33Ia3ofc1vcac8e2efb3b819a7.jpg (13.4 KB, 5 views)
Old 03-12-2012, 07:24 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 95 Eclipse GS-T Ignition problem
Welcome to AF.
Did the timing belt snap on the car? These motors are interference engine so if the belt broke while the car was running there is a good chance it has some bent valves. I would do a compression test on the motor to see if thats the case.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-13-2012, 10:40 AM
steviek's Avatar
steviek steviek is offline
Yea unfortunately it sounds like the motor has been KO'd. + 1 on Compression test.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 03-13-2012, 10:49 AM
steviek's Avatar
FWIW- I normally don't like body kits on eclipses but yours looks pretty good! Also quarter panel vents? Are they functional somehow or just for looks?
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 03-14-2012, 07:21 AM
Holset powered 420a
He only has a lip molded on the stock front bumper. Thats why it doesnt look horrible like other aftermarket front ends. I have always liked them as well
98 Eclipse GS Turbo
2001 BMW 325i - DD
91 eclipse gs automatic throttle problem sith_aries_tiger Eclipse Problem Diagnosis 4 01-11-2008 07:43 PM
95 eclipse GS problem JaggedFel Off-Topic 2 09-20-2004 09:13 PM
1995 Eclipse Gs Notorious Problems EclipseDriver95 Off-Topic 5 01-06-2004 04:56 PM
92 eclipse GS problem help riceizyummy Off-Topic 1 12-18-2003 03:30 AM
90 Eclipse GS-Turbo to a 92 Eclipse GS non-turbo Erdrick191 Off-Topic 0 10-25-2003 01:45 PM
Tags
dsm , eclipse , gs-t
