Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-11-2008, 11:12 AM
sith_aries_tiger sith_aries_tiger is offline
91 eclipse gs automatic throttle problem
Ok I just got this car. When it starts it jumps to 3000 rpms, then it goes down to 1000 then it goes up and down between 1000 and 1500 so long as its in park or nuetral. When I put it into drive or reverse it idles fine. If the car runs for a while it stops all together. I have cleaned the throttle sensor already. Someone told me to change it and the map sensor, but the screw on the bottom of the map sensor is a pain to get to, plus I don't even know if thats the problem. the car runs good other than that. Also very rarely but sometimes when Im slowing down the it will do the idle thing in drive but it only does it like once. Thanks for any help.
Old 01-11-2008, 11:23 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: 91 eclipse gs automatic throttle problem
Sounds like the problem I used to have with my old Firebird... I changed the PCV valve, cleaned my air filter and changed my fuel filter and the problem seemed to disappear... So I have no clue what actually solved it, but I got it solved somehow... Just give the car a well rounded tune up and see if that helps anything. If not, it won't hurt anything to have a tune up for once you do get the problem solved.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 01-11-2008, 04:57 PM
Anyone got any other ideas? Ive cleaned the pcv valve and air filter already
Old 01-11-2008, 06:36 PM
tempfixit tempfixit is offline
What engine?? Is it turbo?
Check Idle Speed Control
Look at autozone.com for repair manual
Old 01-11-2008, 07:43 PM
MazdaX's Avatar
MazdaX MazdaX is offline
Does the 1991 have a IAC ? If so , remove / clean / test again.
2004 Mazda 6i
1997 Tahoe
