Old 09-20-2004, 12:44 PM
JaggedFel JaggedFel is offline
Unhappy 95 eclipse GS problem
hey - i have a 95 eclipse gs, and it was running fine until a week or so ago. what is happening is when i give it gas under 2500rpm it shudders, like the fuel is cutting out or something....... i checked and the plug wires are on, i even ran a bottle of fuel injector cleaner through it, nothing's helping. i was wondering if anybody had any thoughts. thanks!
Old 09-20-2004, 06:22 PM
flyboi06 flyboi06 is offline
Send a message via AIM to flyboi06 Send a message via MSN to flyboi06 Send a message via Yahoo to flyboi06
Post
I had the same problem with my old eclipse which was a 97 rs. What it was, I had ran it hard for a long time. My eclipse ended up needing a tune up. I left it with my familys mechanic and then he took it apart and did w/e he needed to do to it. I know your problem my car would shudder and hesitate when i was leaving stop signs or coming from a stop. It would go fine at higher speeds. But no, i would take it to a mechanic to get it fixed.
Old 09-20-2004, 08:13 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: 95 eclipse GS problem
do a basic tune up. spark plugs, spark plug wires, air filter, fuel filter, clean the throttle body. try that stuff and it should fix it
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
