Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-08-2012, 11:58 PM
RichardC95 RichardC95 is offline
'91 ranger will not start.
Hi I have a '91 ford ranger and i went to gas it up today, and i turned it off to pay. and the next thing it wouldn't start... i had to get a jump start, went home charged it, one start and it wouldn't again. the dummy gauge said it was charging fine... when i turn the ignition there's a single "click", and nothing. The only thing i can think of is putting it in nuetral, put on the parking break, and bypass the starter solonoid...
Old 03-31-2012, 08:33 AM
Bonzo22 Bonzo22 is offline
Re: '91 ranger will not start.
Sounds like a start issue and your starter may be on its way out. Does it start when it is cold without jumping or charging? Also, start checking out the simple things first, battery, cables(tight and clean), wire connections to the starter, etc. After that, if you can get it started, check the voltage at the battery with a multimeter and you should be getting around a 13.7 volt or a little higher charge from the alt. Don't ever trust your idiot gauges.
1993 Ranger will not start with Key 93rangerxlt Ranger | Courier 6 12-06-2006 08:08 AM
1993 Ranger will not start with key 93rangerxlt General Discussion 2 09-01-2006 08:10 PM
'91 F150 Will NOT Start When Humid nuttybar00 F Series 1 02-22-2006 03:03 PM
88 Ranger will not start, but turning over! mustbusmc Ranger | Courier 3 12-07-2005 08:01 PM
1987 Ranger Will Not Start recycleman44 Ranger | Courier 1 08-19-2005 08:52 PM
Tags
1991 , click , ford , ignition , ranger
