Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 09-01-2006, 05:14 PM
93rangerxlt 93rangerxlt is offline
Send a message via MSN to 93rangerxlt Send a message via Yahoo to 93rangerxlt
1993 Ranger will not start with key
Ok first off I am new to this forum, but not to forums at all.
I just bought a 1993 Ford Ranger 4.0L Extended cab and I knew when I bought it that it ran because just in Febuary I replaced the clutch in it.
I got it home and the owner told me how he got it running. He would take a set of jumper cables and hook them to a car and then hook the negative to the negative battery and then to the starter relay (which is not good for the starter). So I replaced the ignition switch which did not fix the problem, replaced the starter that he burned up running it the way he was.
The starter relay is brand new also.
Now I am stumped no power to anything with a good battery and turn the key and nothing happens. The wires to the starter are all good and the wires from the relay are all good. I checked everysingle fuse in the fuse boxes and none are blown so I have no clue and any helped would be appriciated greatly.
I am sure I have left something out so any questions please ask.
Old 09-01-2006, 06:26 PM
reekor reekor is offline
Re: 1993 Ranger will not start with key
Did you check the fuse link???????
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 09-01-2006, 07:10 PM
Smile Re: 1993 Ranger will not start with key
What do you mean by "fuse link"?
Thanks
