Old 03-06-2012, 04:00 PM
dennisditch dennisditch is offline
Question remove rear door with broken latch
how can i remove the rear driver side door when both the inside and outside handles do not release the latch? alternative question how can i release the latch ?
Old 03-06-2012, 09:53 PM
Tech II Tech II is offline
Re: remove rear door with broken latch
Did the inside and outside problem happen at the same time?
Compared to the opposite side door handles, do you feel the same resistance in the handles? If no, then the linkages could have come off(rare to happen at the same time).....
The possibilities are the latch is locked, or rusted and won't release.....can you "feel" the linkage move when you manually lock/unlock the door?
Old 03-06-2012, 09:58 PM
the inside and outside problems happened when my 22 year old gorilla had trouble opening the door so he just pulled harder. then when the outside did not work he moved to the inside.
Old 03-07-2012, 12:37 PM
when i use the manual lock on the inside i can feel resistance and a change. when i pull on either inside or outside handle there is no feel of resistance or change as there is on the other door. my guess either the linkage is off or deformed.
my plans are to loosen the hinge bolts and slide the door slightly forward then try to release the latch. if i can get it released then remove the latch and repair/replace. i have replaced latches and locks in my pickup when i had to replace damaged doors, so i have a hint but i am not an expert.
thanks for any help.
Old 03-08-2012, 12:03 PM
rkvons's Avatar
rkvons rkvons is offline
If it were me, I think I would open up the opposite side door and find out what needs to be moved to get the door open, then, on the trouble side, remove the little plastic trim around the inside door release and go in there with a coat hanger and attempt to snag the thing and pull. I have never tried it, but that's were I'd begin.
Old 03-08-2012, 12:47 PM
thanks i'll give it a try
93 Astro rear door handle broken FLChevman M Bodies 1 03-24-2006 02:47 PM
Removing rear door panel (94 camry) tarunkapoor Camry/Camry Hybrid/Vista 3 08-24-2004 07:57 PM
Removing Rear Door Panels - 2004 Accord flexnix Car Audio 2 05-14-2004 01:36 PM
How to remove rear door panel ('94 grand am)? spedracer1 Grand AM 1 04-23-2004 08:29 PM
97 tahoe need help removing rear door panes sac kings Tahoe 2 09-24-2003 04:49 PM
Tags
door , drivers , rear , side
