Old 03-03-2012, 10:26 PM
mno221 mno221 is offline
Oxygen Sensors
I want to change my bank 1 oxygen sensors on my 2001 Silverado 5.3. My understanding there are two on my exhaust and they are the same, if this is true do any one know the part number for the Denso, or which one would you recommend.
Old 03-03-2012, 11:04 PM
j cAT j cAT is offline
Re: Oxygen Sensors
advance auto has these for 68.oo ea......... or you can get another brand. make sure these are direct fit/proper connector.
not all that complicated on what the part number is . just call and give your vehicle details. the 5.3L engine O2 sensors used cover quite a few model years .
the upstream sensors are the most important on engine management.
Old 03-04-2012, 05:56 PM
Re: Oxygen Sensors
Thanks j cAT
Old 03-11-2012, 03:14 PM
Re: Oxygen Sensors
I replaced both of my oxygen sensors with the Denso 234-4012, that's what was on there. But i'm still getting code P1133. What else could be the problem.
mno221.
Old 03-11-2012, 07:59 PM
777stickman 777stickman is offline
Re: Oxygen Sensors
Check for any exhaust leaks upstream of bank 1 sensor 1.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-11-2012, 09:10 PM
Re: Oxygen Sensors
mno221.
the driverside upsteam O2 sensor is not switching at the proper rate. the voltage must swing 300-600mv at a rate that keeps the computer happy.
this is driverside issue, what can cause this is intake leaks,fuel regulator diaphram leaking fuel,PCV hoses leaking/cracked,and even an exhaust leak on that side which can be the exhaust manifold bolts to engine that do break.
other things like damaged wires/connector in the sensor circuit can cause this.
Oxygen Sensor sasheehan Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 6 04-01-2012 09:19 PM
Cleaning O2 Sensors CCMphysician Engineering/ Technical 4 01-15-2010 08:47 AM
97 camry V6 02 sensor help!! machinehead26 Camry/Camry Hybrid/Vista 3 10-25-2009 08:44 PM
is it weird my oxygen sensots voltage changes WHEN THEY'RE UNPLUGGED? bac512 Savana 0 07-29-2009 11:20 PM
o2 sensor danielgast46 F Series 0 03-15-2009 10:39 PM
