Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-24-2009, 09:36 PM
machinehead26 machinehead26 is offline
97 camry V6 02 sensor help!!
I got a 97 camry V6 and I just replaced both upstream oxygen sensor, the car runs so much smoother now. But the problem is the same check engine light came back on after a couple miles of driving. Any ideas why is this happening?
trouble codes is P0130 bank 1 sensor
P0133
P0150 bank 2 sensor
P0153
Old 10-25-2009, 02:39 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 97 camry V6 02 sensor help!!
http://www.obd-codes.com/p0130
http://www.obd-codes.com/p0133
P0150 and 153 same except bank 2 sensor
Double check connections and concider using OEM sensors if you didn't. Any exhaust leaks?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 10-25-2009, 03:09 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
It may be that your Engine Coolant Temperature sensor is malfunctioning and you are never going into closed-loop metering. Check the ECT sensor.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 10-25-2009, 07:44 PM
Nope no leak
Tags
02sensor , oxygen , sensor
