Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 02-29-2012, 09:53 PM
onio420 onio420 is offline
irregular idle 22re
when my truck is at a high rpm it does fine but when i brake it starts dropping , when i let go the brake it starts to get higher, and when i close to 3000 rpm, someone help me please.
Old 03-01-2012, 08:21 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: irregular idle 22re
Most common cause is from the idle rpm being higher than spec to begin with, make sure it's in spec. Another possible cause could be low coolant level or bad coolant temp sensor.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Hi irregular idle 22RE cris8746 Pick-Up 3 03-14-2015 02:46 PM
92 Jetta irregular idle MadDogDoyle '91 - '96 2 06-30-2006 10:32 AM
Irregular idle kboogie Grand AM 6 12-31-2004 08:53 PM
Irregular idling problem with 4cyl Sonata yendor Sonata 1 05-28-2004 05:08 PM
'94 Taurus irregular idle. a_stupid_box Taurus | Taurus Wagon 3 05-01-2004 04:58 PM
