Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 08-16-2003, 06:28 AM
yendor yendor is offline
Question Irregular idling problem with 4cyl Sonata
Can anyone give me an idea what would be the problem with irregular idling with the twin cam 2litre Sonata??
Old 05-28-2004, 05:08 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
Re: Irregular idling problem with 4cyl Sonata
yes ,its called idle surge and a few things can cause it,plugs,wires,coil,air filter,and then while the car is running spray some starting fluid on and around the intake manifold to check for leaks! if the engine revs up then you know you have a leak, also spray all the hose connections, where the intake manifold meets the head, and any other connection that looks as if its vacuum related,cuz if you have a vacum leak that also is a cause,lets see what else,oh,isc,your idle speed control,try that
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Stalling problems with 99 Sonata sun_Shine Sonata 12 09-19-2008 08:44 PM
Idle/Problems with dying BigRed97 Neon | Plymouth Neon 3 10-08-2003 11:29 AM
idle problem with b16 in 93 cx RandomTask76 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 05-12-2003 08:10 PM
Idle problems with 89 Civic jmk_98513 '88 - '91 Civic | CRX | Wagon | Shuttlee 9 04-04-2003 09:03 PM
Idle problem with B16a2 zippeay Engineering/ Technical 5 02-07-2003 04:58 PM
