Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-29-2012, 01:30 PM
troublerodeo2000 troublerodeo2000 is offline
tranny perplexing problem
I have a 2000 isuzu rodeo. The shifter indicator lights on the dash fluctuated and eventually went off. It shifts hard from 1st to 2nd and grinds coming to a stop. The cruise control does not work (All this happened at the same time). I've read many posts about it being the neutral saftey switch and I have replaced it. Nothing has changed, the lights have not come on or anything. I've checked the trans fluid and its good. Any help would be great.
Old 02-29-2012, 08:14 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: tranny perplexing problem
Your range selector is dirty or just replace it.
http://www.walkerdowney.com/ryanendres//isuzu/#faq59
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-01-2012, 06:13 PM
Thanks for responding. Before posting my original thread I put a new neutral saftey switch (the small black half circular box with a wire harness on the side of the transmission) or what you call a range sensor and nothing has changed. Any other ideas.
Thanks
Old 03-01-2012, 08:27 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Originally Posted by troublerodeo2000 View Post
... Before posting my original thread I put a new neutral saftey switch (the small black half circular box with a wire harness on the side of the transmission) or what you call a range sensor and nothing has changed. Any other ideas.
Thanks
H'mm, that is strange, a bad range switch (aka mode switch) is the usual cause of the symptoms you describe. Had the same thing on my 2000 Trooper. If you find another cause be sure to post back.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
96 sc tranny problems please help phantom309 SC/SL/SW 6 04-28-2009 02:27 PM
Perplexing problem bigbadbronxy2k5 Lumina 5 04-22-2009 09:17 PM
92' S-10 Tranny problem AK47 SRH420 Interior | Exterior | Appearance 3 02-20-2009 03:41 PM
1998 VW Passat Tranny Jerks! Problem with Tranny? or Engine? serjay '97+ 0 06-10-2006 09:56 PM
1998 BONNEVILLE SSEi, perplexing problems! trshinn Bonneville 1 04-19-2004 10:32 PM
