Go Back   Automotive Forums Car Chat > Chrysler > Cirrus
Old 02-28-2012, 09:19 AM
burned burned is offline
96 cirrus LXI sometimes hard start
The girlfriend has one of these cars. New to me. Sometimes it is hard to start. I have checked the charging system and that checks out ok. I did notice that when it is hard to start the rpm gauge goes wacky for a couple of seconds after it starts. I am thinking something wrong with the crank sensor. Any other ideas? I also noticed that the "absolute throttle position" is reading 16% at idle with my scan tool. Maybe cleaning the throttle body and further testing of the TPS with a meter is in order.
Old 03-17-2012, 06:38 PM
Mx5guy Mx5guy is offline
Send a message via AIM to Mx5guy Send a message via Yahoo to Mx5guy
Re: 96 cirrus LXI sometimes hard start
Ok while a throttle body cleaning can go great lengths, what are the fault codes if any, is this the 4 or 6 cylinders? RPM going wacky could be a pointer of an ECM going south. I suggest more testing, code retrieving and go on clean throttle body. Good luck buddy. :-)
Old 03-17-2012, 07:31 PM
Its a 2.5L V6, there are no DTC's. The ECU gets the RPM from the crank or cam sensor. I think those sensors would more likely be a culprit. I have heard oil can sometimes containment the crank sensor. The tach only freaks out on start up.
Old 03-17-2012, 08:49 PM
If you have no codes I will start suspecting gas delivery problems like a seriously clogged fuel filter or a fuel pump going south, I would test fuel pump pressure at this point. Sensors are completely ruled out at this point, if the diagnostic system OBDII in the car is working properly a faulty sensor will trigger a code ;-) Good luck.
Old 03-18-2012, 01:16 AM
I was thinking of changing the fuel filter as well as the plugs, wires, cap and rotor. Fuel tank has to be dropped to access the fuel filter. What an idiotic setup! Thx
Old 03-18-2012, 07:31 AM
Yep changing all those things as a tune up won't hurt either, Idiotic setup in that fuel filter? yep I give u that one the only car I've seen with such a complicated filter setup. Good luck !
95 cirrus hard start , rough / no idle spiritwild Cirrus 2 03-20-2011 05:06 PM
Grand Am, Erratice hard starting ChiLLX Grand AM 3 10-23-2010 04:21 PM
Hard/no start/stall/hunt when hot... only on start up save_me_jebus Mustang Problem Diagnosis 4 08-03-2010 12:20 AM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 08:52 PM
'96 Cirrus hard starting sog Cirrus 3 06-12-2005 05:01 PM
