Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 02-27-2012, 02:25 AM
edcal edcal is offline
Smile 1992 Transport window not working
Hello all. This is my first time posting a thread. Pass and driver side windows have not been working. I replace all switches, fuses, circuit breakers, relays and still no change. The only thing that makes these windows work is hooking up to a battery and they work fine. Now driver side circuit test with 12 volt tester (light) comes on when i touch the each wire going into the window motor and I'm not pressing up or down on window switch. If I press the switch button for up and down the light stays lit on both wires. 2: When I touch the tester to pass side wires connected to motor and press up or down the light will come on and off for each wire touched. I'm thinking its a grounding problem on drivers side or a short somewhere. I have done many repairs on this vehicle but this one got me stumped. Any suggestions would be very much appreciated.
Old 02-27-2012, 06:24 AM
LMP's Avatar
LMP LMP is offline
Re: 1992 Transport window not working
You're probably right. It seems you know how the circuit works but just in case
www.avigex.ca/xport/pwrwindows.jpg
All wires going to motors from driver switch should read zero when switches not pressed on. If you have voltage, it has to come either from stray conduction through the switch or through the switch lamps..if interior lights are turned on or at night and if ground B is lost....Contact B at the driver side switch should read zero in all conditions....maybe a fraction of a volt when a window actually moves up or down.
I'm looking for an existing thread about the location of the grounding post..under the floor carpet....and will post a link asap.
IN the mean time, test a separate ground connection to contact B (black wire) and see what happens.
LINK: not exactly what I was loolking for but it can brng some ideas....http://www.automotiveforums.com/vbul...d.php?t=658078
...and kind of similar problems
http://www.automotiveforums.com/vbul...d.php?t=893854
http://www.automotiveforums.com/vbul...d.php?t=644937
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
The Following User Says Thank You to LMP For This Useful Post:
edcal (02-28-2012)
Old 02-27-2012, 09:29 AM
Tech II Tech II is offline
Not sure if I am reading you right.....
If you disconnect the harness to the motor, and attach a test light to the harness, the light should be off...when you press up OR down on the switch, it should light(all the switch is doing, is reversing the polarity of the voltage when completing the circuit)....is that how you are testing it?
There should be NO POWER TO THE HARNESS, when the switch is not pressed.......Which switches have you replaced?
Old 02-27-2012, 08:50 PM
Wink Re: 1992 Transport window not working
Tech II: Harness are connected to window motor while I have the test light probe in through the wire insulation to touch wire. Its those kind of testers that you stab through the wire insulation. The driver side has power in both wires at all times and when I press up or down power button there is no change. It just stays on. Both windows switches were replaced. I'm going out now to try some other test suggested by LMP to see what happens.
Old 02-27-2012, 09:36 PM
Ok, I used an alternate ground source for connection B and the window goes up and down but in reverse order. Press to go up and goes down and vice a versa. Sure got me excited. lol But forgot to rehook the passenger side wires but will do in a bit but I just go sidetracked. BRB
Old 02-28-2012, 02:20 AM
Thanks LMP for all the info. Windows working now and now on to the next problem or should I say problems.
automatic locks and driver side window not working rmwilson Problem Diagnosis 5 06-23-2010 08:04 AM
1992 Airconditioning Is Not Working Techventure Camry/Camry Hybrid/Vista 5 06-14-2007 09:08 PM
1992 4x4 button not working bser911 Explorer | Explorer Sport Trac 2 12-09-2006 04:24 PM
1992 Keyless Entry not working 92blazer Blazer 1 10-27-2004 10:27 PM
automatic windows not working jeepbay Grand Cherokee | Grand Cherokee SRT8 2 11-24-2003 02:36 PM
