Old 02-25-2012, 04:14 PM
jesterjoe jesterjoe is offline
2004 chevy cavilier not running
i have 2 questions, when i plug in a autoscanner to my car it wont power on.....but when plugged into any other car it works fine. is there a fuse or something that runs the actual plug in.......
second question the car is not getting fuel it keeps dying but when i jacked up the car and beat on the bottom of the gas tank the fuel pump started working just fine again i dropped the car off the jacks drove it around the block it worked fine again until i moved it into the garage it seems to be draining all the power out of the battery when u try to start it after this problem occurs could this be a for certain the fuel pumps bad?
Old 02-25-2012, 06:10 PM
jamesslcx jamesslcx is offline
Re: 2004 chevy cavilier not running
jesterjoe did you turn your ignition switch on after you plugged in your scanner? It really sounds like you have a bad fuel pump, sometimes jarring them will get them working again for a while.
The Following User Says Thank You to jamesslcx For This Useful Post:
jesterjoe (02-25-2012)
Old 02-25-2012, 06:55 PM
yea i turned the key over on the car when scanner was plugged in like i said it worked on every car but mine so i did not know if i blew a fuse......... and i will replace the fuel pump
Old 02-25-2012, 08:19 PM
Jesterjoe that's very strange the scanner couldn't connect to your car, along with the fuse check the connector in your car for separated or bent pins just to be on the safe side and work from there. Let us know and good luck.
Old 02-25-2012, 10:35 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Power for the ALDL connector is usually the same fuse for the cig lighter.
Old 03-11-2012, 12:46 AM
Mangoamerican Mangoamerican is offline
Send a message via ICQ to Mangoamerican Send a message via Yahoo to Mangoamerican
check the ground going to the engine block.
2004 chevy cavilier pawnseven7 Cavalier 1 07-31-2009 01:42 PM
2004 chevy cavilier pawnseven7 Cavalier Problem Diagnosis 0 07-11-2009 12:56 PM
2004 Chevy Express, no run no start-- nothing 92IROC Express | G Van 3 03-19-2009 09:57 AM
2004 chevy malibu not starting and dying tonyalyn2000 Malibu 9 10-17-2004 10:08 PM
DRL's (Daytime Running Lamps) for 2004 Chevy Cavilier rklesla Cavalier 3 03-19-2004 10:16 AM
