Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-25-2012, 06:51 AM
predator247365 predator247365 is offline
92 talon engine skips under boost around 4500 rpm's
ok i have a 92 talon tsi awd and here lately i notice when i go full throttle under boost it pulls hard to around 4500 rpm's then it starts skipping like it has a boost leak but iv done a boost leak test and have no boost leaks iv rebuilt throttle body ,put new plugs and wires,checked coil,checked vacuum lines no leaks...when i put new plugs in the old ones were brown if that helps anybody i put new fuel filter on and i have a walbro 255 iv lost my cool with this car bout ready to git rid of it can someone plz help me!!!
Old 03-13-2012, 09:44 AM
steviek's Avatar
steviek steviek is offline
Re: 92 talon engine skips under boost around 4500 rpm's
What turbo are you running and at how many PSI? It seems alot to me like your hitting fuel cut. Either that or your A/F ratios are way off some other way.
My first suggestion would be turn down the boost and see if that delays the stuttering. If it does then we can assume that the decreased airflow enabled the car to have target A/f ratios longer. That would be indicating fuel cut. Stock 450ccs? No engine management? A likely factor on a aftermarket turbo.
If its a boost leak then the test should have shown it.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 03-13-2012, 09:45 AM
steviek's Avatar
Re: engine skips under boost around 4500 rpm's
Do you have a wideband A/f gauge? or EGT gauge? These will also tell us if the engine is going way lean or rich. Likely lean.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 03-14-2012, 05:39 AM
iv got 550 injectors 16 g turbo no engine management running on maf with cones taken out also have fuel pres reg set on 40psi...i did a pull yest and it didnt skip at all in first when i went to sec and it got to 5000 it did the mild skip again but seems to still pull hard and im running on wastegate pressure
Old 03-14-2012, 06:26 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Sounds like you figured out your problem. Bigger injectors with no engine management. You need to get a wideband o2 and a SAFC at the bare minimum. By lowering the base fuel pressure you can "scale" the 550s to run like 450s as far as the ECU is concerned with fuel trims and such but this also means your 550s will max just like the 450s did. You need to run stock base fuel pressure and tune the injectors down by a different method.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-14-2012, 06:36 AM
thx people im supposed to be getting a afc neo this weekend hope this fixes my problem also got my eye on a wideband ...
Old 03-14-2012, 03:34 PM
steviek's Avatar
Yea and just as a side note. You flow much more airflow in second then you do in first. So its completely understandable that you wouldn't have them maxed in first (too fast for turbo to get all the way up) vs in second.
I have a thread in the tech articles about tuning your a/f ratios with an afc. You should read up before you get started.
Let us know
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Surge, skipping under load Eskareon Park Avenue 31 02-22-2006 11:36 PM
94 4.3 Vortec skipping under load french69ssrs S-10 4 11-05-2005 05:05 PM
Insane Jerking around 4500-5000 Rpms 1995EclipseGS Eclipse Problem Diagnosis 0 03-14-2005 12:17 PM
Missfire below 4500 RPM's earlpitts Off-Topic 26 10-24-2004 08:03 PM
Engine management- Detonation under boost ZORT Forced Induction 11 03-28-2004 03:06 AM
