Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-06-2002, 04:50 PM
ZORT ZORT is offline
Engine management- Detonation under boost
Folks I am new to the forum and own a D16A9. It doesn't have an o2 sensor so does it mean that I have a knock sensor?
And wouldn't this knock sensor assist in me not denoting under boost?
Old 06-06-2002, 08:50 PM
EightOhOne's Avatar
EightOhOne EightOhOne is offline
why doesnt your car have an o2 sensor? It should have one, or its going to affect the way it runs. If youre detonating under boost, that knock sensor is going to help minimally. What turbo/fuel setup are you running, and whens the detonating occuring? Is your ignition timing retarded any?
Old 06-07-2002, 11:33 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
i dont think any D series motor came with a knock sensor. the current D series motors dont.
are you carbed or fuel injected? D16A came with either one back in those days.
Old 06-07-2002, 01:08 PM
I have a D16A9 EFT it came stock with no catlyic convertor, and well no o2 sensor. On the exhaust manifold you can actually see the opening in the heat shield where the o2 sensor should have been and on the manifold it self the port for the o2 sensor is actually blocked (not by someone it look stock as if the factory did it)
I am preparing for my turbo setup. I decided on an FMU for extra fuel pressure in boost. So I have not set it up as yet..
Old 06-08-2002, 06:19 AM
drift's Avatar
i HIGHLY reccommend getting an aftermarket O2 sensor and air/fuel monitor... it's imperative for tuning a turbocharged car, especially for motors not normally equipped for turbocharging.
Old 06-08-2002, 03:58 PM
Gonthrax's Avatar
Gonthrax Gonthrax is offline
Skyline Guy
Send a message via AIM to Gonthrax
I would have thought that any fuel injected moter would have an o2 sensor...
A knock sensor will let you know right before things go horribly wrong, so I second the recomendations for an A/R meter. A little one with the rows of LEDs should suffice.
Member of AF's Slide Squad (Member #04)
Originally posted by taranaki
Postcounts - Phoey....it's not how often you speak,it's whether you actually say anything that matters.
Neishlin Motors
Soon to be my best friend
Old 06-09-2002, 10:40 PM
Various types of O2 sensors..
I was just going with the Autometer one. But if there is something less expensive, hey tell about it..
Old 03-16-2004, 03:16 PM
blanchi blanchi is offline
Re: Various types of O2 sensors..
I live in the uk and also have this problem! I own a rover 216 gti with a honda d16a9 eingine but since my car is pre 1993 it does not have a cat which means no lambda sensor. This limits me to tuneing as all ecu upgrades need a o2 sensor to work! Can any one help?
Old 03-16-2004, 03:45 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
Re: Re: Various types of O2 sensors..
uh... how about buying an o2 sensor?
P.S. The knock prevention systems that i'm familiar with dont 'tell' you anything. If your engine detonates it retards your ignition to prevent further detonation. probably wouldn't do too much good on a turbo, since that'll just increase your exhaust temp and give more powah to the turbo. I recommend the A/F meter from http://www.dawesdevices.com
Old 03-17-2004, 01:45 PM
Re: Engine management- Detonation under boost
Thanx for the advice. I have order a air fuel ratio meter now and will post another message to tell you what progress was made! THANX!
Old 03-24-2004, 09:35 AM
88_SC_CRX_Si 88_SC_CRX_Si is offline
The A/F ratio gauge using a single wire OEM O2 sensor is not very accurate at all, and should only be used as a tuning aid only. The color of the plugs will be the finale judge. On where the fuel pressure should be set at, rather then what the gauge is telling you. It could very easily blow an engine, just by using it...
Some peeps will tell you to save your $$$$$ because of the above mentioned. Using a Wide Band O2 or going by Exhaust Gas Temps, is about the only way to tell, what the actual ratio is.
There are few companies out there, that say they can mod the AM gauge to make it a lot more accurate.
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
Old 03-28-2004, 04:06 AM
racerex racerex is offline
Honda began using knock sensors with OBD-II and no it will not save your motor from boost.
'89 GMC Engine Ping/Detonation Issue PeteA216 Sierra 5 03-19-2008 10:45 AM
suggested compression ratio under boost TURBOACCORD N2O | Turbo | Superchargers 11 05-19-2004 10:55 PM
Need help FAST!!! Car is running lean under boost IntegraB18LS Forced Induction 10 03-12-2004 10:34 PM
Misfires Under boost swest_jefe Off-Topic 6 10-13-2003 08:37 PM
cooling system under boost dominate9 Forced Induction 5 01-26-2003 06:00 PM
