Old 10-11-2004, 04:10 PM
earlpitts earlpitts is offline
Angry Missfire below 4500 RPM's
I have a '95 non-turbo eclipse. It seems to misfire below 4500 rpm's, the idle is a bit rough but not terrible. Sometimes when letting off the gas it takes a few seconds to idle down staying at around 2500. I've changed plugs (twice) and just now changed wires, no change... I've run out of things to do... any help??? Thanks
Earl Pitts..... Proud To Be An Uhmerikun!
Old 10-11-2004, 06:14 PM
Follow up
Ok here is more info. I just re-gapped the plugs @ .050 (they were clean) and cleaned the ITS, it seems to have helped the idle a bit but still it misfires and loses power below 4K-4.5K. After it reaches around 4k it runs awesome, lots of power and smooth. Could it possibly be a coil pack? (it checks good) Crank or Cam sensors? Geeeze
Old 10-12-2004, 05:26 AM
Re: Missfire below 4500 RPM's
No help on this? I suppose my problem is to common with these clunkers, read several (and I di mean several) post about these problems and they all seem to be hit and miss about what it takes to repair. Guess I'll just keep driving it til whatever it is falls off.
Old 10-12-2004, 05:43 AM
BlackSpyder1998 BlackSpyder1998 is offline
I have the same problem with my car but I only get it at idle I dont feel it when driving, Im going to change my plug wires and the fuel filter see if this gets rid of the problem it all started when I changed the plugs to the BPR6ES instead of the BPR6EKN so that might be the problem to
[IMG][/IMG]
Old 10-12-2004, 08:18 AM
RiceRocket18's Avatar
RiceRocket18 RiceRocket18 is offline
Send a message via AIM to RiceRocket18
it's strange.... seems all all have similar but not exact same problem. my situation is that after i change my stock plugs to NGK 7es (300mi after) it started misfire below 1500rpm. it usually gets better after it warms up. usually it's the worst when i take her out first time in the morning. i am going to try and gap them again or switch to the factory sometime later in the future. got a more serious problem in hand right now.
06 Charger SRT-8 black.
Old 10-12-2004, 11:00 AM
EclipseBabe95 EclipseBabe95 is offline
same problem here, try gapping the plugs down.... i have the same eclipse as you and i regapped the new plugs at .040 and the problem vanished.
-a
BUY MY CAR!!!! www.clarkson.edu/~desjarrf/keldra.htm
very reasonable price....
[email protected]
Potsdam, NY
2001 Yamaha YZF600R
95 Eclipse GS
Old 10-12-2004, 11:22 AM
.04?.. isn't the default should be .028. opening it up more will just make the misfire worse.
Old 10-12-2004, 06:30 PM
btw....
Old 10-12-2004, 08:18 PM
my factory manual for the gs says .050 is standard, but a lesser gap performs so much better.
-a
[email protected]
Potsdam, NY
2001 Yamaha YZF600R
95 Eclipse GS
Old 10-12-2004, 08:37 PM
so, should I gap the plugs at .028? Ive tried both .040 and .050 (yes the manual says .050) Just throws me for a loop as to why the thing runs so smooth after 4k.. its like the turbo kicks in... but yet I have NO turbo!!
Old 10-12-2004, 10:07 PM
.028 is the number for all NGK BPR7ES. perhaps i can try gap it down to .026 see if that helps.
Old 10-13-2004, 01:34 AM
I have the BPR6ES and have them gapped at .029 I will try to bring them down to .026 but is this wise. the only mods i have are intake and exhaust. but I have the stock wires so this might be the problem but i will reggap them first
[IMG][/IMG]
Old 10-13-2004, 02:41 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
.28 is turbo, .40 or whatever is non turbo.
Old 10-13-2004, 05:38 AM
sooooooo having them gapped at .040 and still having the problem.... I need to look elsewhere... other than plugs?? I'm 'bout ready to try 4-sale to see if that fixes it.
Old 10-13-2004, 06:41 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Do you have a check engine light?
For Sale 98 Eclipse GS, 5 spd
