Old 02-21-2012, 10:33 PM
bsr2002 bsr2002 is offline
Replace Radiator
It's purtie strait foward? Looks like I just take the fans and it should come out?
2003 Trailblazer LS 4.2L
www.facebook.com/bennyrillo
Old 02-22-2012, 12:53 PM
rkvons's Avatar
rkvons rkvons is offline
Re: Replace Radiator
You may have to disconnect trans cooler lines at the bottom, two radiator hoses, overflow hose, coolant level sensor connector, if there, etc.
Old 02-22-2012, 07:58 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
I'm gonna be doing mine here soon. All the above, but yeah, not difficult.
Save that aluminum core and pull the tank off the transcooler side...that transcooler is a nice chunk of brass. Good for a few bucks at the metal recyclers. Might as well get some money back outta the deal...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 02-29-2012, 04:48 PM
A little more while it's fresh in my mind, I just finished replacing mine.
First off, that transcooler is NOT brass in this one, so don't waste a lot of time trying to recover it like I did ...it looks like anodized stainless steel...worthless as far as scrap.
Make sure you take notice of the two metal brackets that piggy back on the top and bottom of the radiator core, they support the fans and the transcooler lines, you'll have to remove them from the old one and put them on the new one if yours didn't come with them...mine didn't.
And don't forget the low coolant switch on the passenger's side tank, you have to slip a long screwdriver down there to spread the catch on the plug and unplug it. There's a wire thing that locks the switch into the tank...take it off carefully and make sure it doesn't spring away so you spend 15 minutes looking for it like I did...duh.
The easiest route for me was to remove the passenger's side fan first, the other one I didn't remove from the car completely...just set it back against the motor out of the way...it can drop down between the motor and the subframe member and stays outta the way pretty good.
And, as with just about every other damn thing you do to this car, it's easier if you completely remove the airbox. I don't know how they managed to make this thing so in the way of everything you gotta do, but they did. I swear if you wanted to put rear brakes on it, you'd probably have to take the damn airbox out for some reason
...empty gun rack.
Old 05-22-2012, 02:00 PM
Thanks! I finally got round to it this past Saturday, The only real problem I had was with the transcoolant lines.
I couldn't get them off. Finally used a pipe wrench on the top one and it worked.
The bottom one I couldn't fit the wrench in. So I had to break down and hacksaw the bottom transcoolant line.
I patched it back up with heater hose and double clamped it. Works like a charm!
Old 05-23-2012, 02:08 AM
Schurkey Schurkey is offline
And of course you verified that the hose you used is compatible with the heat and the chemical nature of ATF?
Do you have any idea how flammable ATF is when aerosolized by the radiator fan and blown onto the exhaust manifold?
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 05-23-2012, 05:25 PM
True...you need to use hot oil transfer line, or it won't last long....
...empty gun rack.
Old 05-24-2012, 05:39 PM
I should have said temporary, I got trans hose today!
Old 05-24-2012, 07:12 PM
Good man!
...empty gun rack.
96 teg radiator replacement joshjohnson_79 Integra 0 10-24-2010 01:40 AM
how do I replace radiator fan sbraddo Caravan | Voyager 8 09-21-2004 10:52 PM
replacing radiator Hanover13 Accord/TSX/Accord Hybrid 5 04-14-2004 11:35 AM
replacing radiator Hanover13 Accord/TSX/Accord Hybrid 1 04-13-2004 02:41 AM
looking for a replacement radiator Mac8008 3 Series 0 11-12-2003 02:34 AM
