Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 02-20-2012, 10:59 AM
mrgaray mrgaray is offline
code number P1409
2001 Ford Escape 2wd V6, check engine light came on and i check to see wat it was, and this code came up on my scanner P1409. From looking into my book i have several things that can cause this, how do i know what its causing this code to appear, EGR valve? EGR vacuum? EGR system sensor? without spending to much money.
Old 02-20-2012, 03:17 PM
65comet's Avatar
65comet 65comet is offline
Re: code number P1409
Search for catalytic converter in this Escape forum. Your main cat is probably plugged by the insides of one of the 2 small ones (junk) that are part of the exhaust manifolds. This causes tremendous exhaust pressure to go up the EGR tube. On my 02 it actually caused the EGR to explode! Disconnect that tube from the EGR and see how much pressure is coming through.
Old 02-22-2012, 09:00 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Make sure your EVR is plugged in. The EVR control solenoid is located on the back of the intake manifold closest to the driver side, its a small piece of black plastic with a circle shaped top. There is 2 vacuum lines that plug into it and a wiring harness, make sure the harness insulation isnt falling apart, make sure your vacuum lines are plugged in and not broken at any point.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 02-26-2012, 03:02 PM
thank you guys for your help on this code, i will check all the hoses and wires and make sure it is all connected and nothing is broken, once again thank you very much.......
01 Sport Trac Door Code??? levi.calhoun Explorer | Explorer Sport Trac 1 03-23-2009 10:09 PM
How to get the Fixed # and Code number for 91-Maxima czskill Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 01-17-2006 03:18 PM
Code Number P1443 98PPORT Thunderbird 0 02-12-2005 12:52 PM
1988 Legend - Code number 8 Cindimccs Legend | RL 0 07-11-2002 10:00 PM
Code number 41. Frostbyte Engineering/ Technical 1 03-27-2002 07:10 PM
