Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 02-15-2012, 09:52 PM
tempfixit tempfixit is offline
97 code P1443
97 2.3 engine 175k (short wheel base)
Neighbor just bought this vehicle, Code P1443 present. The CEl is intermitent, she told me tonight that when she fueled up she had a hard time fueling. The fuel input could only be done at a trickle mode otherwise dispenser would click off. I am thinking this is a Evaporative Emission Valve issue in the tank.
When I get a chance I will check for bad line but i am thinking that valve stays closed so the vapors do not escape during filling thus fuel is being blocked from entering tank.
Thanks for any and input.
Has anyone had problems with the Filler Neck tube hose collasping??? The aftermarket filler necks are $180.
PS: Is ther a issue with the vent tubes on the filler neck????
Old 02-17-2012, 08:51 AM
Re: 97 code P1443
Has anyone had trouble with their filler neck tube hose collasping.
Old 03-09-2012, 06:30 PM
samprix samprix is offline
Re: 97 code P1443
I have the same code on my '96 with 3.0 and 4x4. I have seen posted at other sites that this code can be solved by replacing the canister purge solenoid valve. There is a hose that runs from the canister to the intake with a valve in line, I think. The valve is bad or the hose leaks and we get P1443. I have not tried the repair yet. Has anyone else had success with this? I'll post my results if I ever get to it. Too many vehicles.
Old 03-09-2012, 09:09 PM
Re: 97 code P1443
Sorry I had forgotten I posted this.
I replaced the line from intake to canister and cleared code, it stayed off for a while. The other day she told me that the cel comes on when the tank seems to get to 1/2 area. I suspect it needs a new gas cap but have not tried that yet. I will let you know if it works also.
What is code p1443?? renskee1sfk Escort 2 03-07-2010 01:36 PM
1996 Escort Engine light code P1443 bensnelda Escort 4 08-15-2005 04:30 AM
1996 Ranger Code-P1443 Help help casperslee Ranger | Courier 3 07-14-2005 03:46 PM
97 Escort 2.0L Emission Error Code P1443 weidnerr Escort 1 08-05-2004 05:47 PM
2000 Outback check engine code P1443 jbrusso Outback 1 06-22-2004 08:05 PM
