Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 05-24-2005, 12:13 PM
casperslee casperslee is offline
Send a message via Yahoo to casperslee
Smile 1996 Ranger Code-P1443 Help help
My check engine light is on. The truck seems to hesitate at times.
The code- is the (Auxillary Emissions Control) "Autozone says its the "Evaporated Emissions Control Systen Control Valve." So, Where is it ?????????????????????????
Old 05-25-2005, 08:48 AM
splashiod's Avatar
splashiod splashiod is offline
I had same code on my 95 3.0. It ended up being the "purge valve selinoid". It's a small cylinder with in/out vacuum hose & an electrical connection. It's on driver's side fenderwell, hose running to carbon canister. Check all hoses also for vacuum leaks. Part cost $65 at dealer. Good Luck!
Old 07-13-2005, 01:26 PM
Re: 1996 Ranger Code-P1443 Help help
HELP HELP>> AGAIN! >>I changed the purge valve selenoid,.. check engine light is back on. now what?
Old 07-14-2005, 03:46 PM
splashiod's Avatar
I assume you did unhook battery for 10-15 minutes to clear computer. Go have AutoZone read code again to make sure same code. Check that hoses are not cracked or stopped up also, & make sure selenoid is going in correct direction, there's an arrow on it. Good Luck!!
