Old 02-14-2012, 09:01 AM
snorander's Avatar
snorander snorander is offline
Now low speeds on blower motor
Hi,
I have a 2001 GMC Jimmy and I am having an issue with the blower motor. Speeds 1 and 2 do not seem to work. Speeds 3 and 4 work fine. This is the manual climate control not the automatic. I searched and it seems everyone usually has a problem with the high speeds & not the low speeds....Any help would be greatly appreciated.
Steve
Old 02-14-2012, 09:22 AM
paulmagee paulmagee is offline
Re: Now low speeds on blower motor
right beside the blower motor there should be a climate control has a plug in with two bolts holding it on many times it is that unit that is bad sometimes debri pens clips falling down through dash vents drops down in there and fan makes them bounce off the unit causing it to break the circuit board
Old 02-14-2012, 12:20 PM
snorander's Avatar
Ok so I should look under the hood by the blower motor. Is it on the plastic shroud or near it?
Thanks,
Steve
Old 02-14-2012, 04:33 PM
old_master's Avatar
Advisor/Moderator
Yes, under the hood, two screws hold it into the black plastic evaporator housing. The part is a "blower motor resistor". If high speed and at least one other speed work properly, this is almost certain to be the problem. http://shop.advanceautoparts.com/web...RPSESWAMS_____
You have to know how it works,
to figure out why it doesn't.
Old 02-14-2012, 05:01 PM
snorander's Avatar
Ok I feel stupid, I don't see it, do I have to remove/cut the plastic cover? can you see it in either of these two pictures?
Thanks!
Steve
Old 02-14-2012, 05:23 PM
old_master's Avatar
Advisor/Moderator
Yup, bottom image. Says "CUT HERE FOR SERVICE". Use a utility knife being careful not to cut to deeply.
Old 02-14-2012, 06:01 PM
snorander's Avatar
Thanks OM much appreciated! That plastic is brittle & falling apart as it is, but I'll be gentle
Old 02-14-2012, 06:14 PM
old_master's Avatar
Advisor/Moderator
That's why I said be careful That stuff crumbles after about 5 years.
Old 02-15-2012, 05:43 PM
snorander's Avatar
Thank you very much Paul & OM. $17.99 for the part, 15 min. of my time and all is back to normal!
Thanks guys!!
-Steve
P.S. I'm getting close to the big 200,000 only about 4,500+/- miles to go!!! This site has certainly help my truck make it this far....Other than having to replace the tranny around 130,000, and the intake gaskets last spring it has been mostly smooth sailing....
Old 02-15-2012, 08:57 PM
old_master's Avatar
Advisor/Moderator
That's why we're here, love to share knowledge & experience. Good job, Steve. Thanks for posting back.
High Speed Blower Motor Relay Module Rythymaxe Bonneville 1 08-04-2008 02:41 PM
Blower motor speed varies with speed JohnABurns Lumina 3 01-29-2008 11:08 AM
No Low or High Speed for Blower Motor StevePT Grand Prix 5 09-20-2005 01:52 PM
Low speed fan motor JPenkert LeSabre 1 08-03-2005 04:26 PM
a/c blower switch or blower motor? Aggrev8ed GTP Ownr Grand Prix 5 06-28-2004 10:35 PM
