Old 01-06-2008, 06:25 AM
JohnABurns JohnABurns is offline
Blower motor speed varies with speed
I have a 96 with 3.1. Fan speed is ok when I start but as I slow down to stop the speed decreases and then picks up as I accelerate. The headlights and turn signals will effect it also. Any input is appreciated. Thanks
Old 01-06-2008, 09:42 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Blower motor speed varies with speed
Sounds like your alternator might be failing...get it's output checked, or you could get stranded....
Usually when you notice something like that, there's not enough voltage under load, the accessory pulling the most load will cut back...output is lowest at idle.
Otherwise it could be a bad ground in the blower circuit or something...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 01-07-2008, 04:58 PM
KKLumina KKLumina is offline
... or a bad belt tensioner.
Old 01-29-2008, 11:08 AM
nascartony05's Avatar
nascartony05 nascartony05 is offline
I have had one with similar symptoms and it turned out to be a vaccuum line at the canister.(front left hand side?)
