Old 02-05-2012, 03:33 PM
Lamorake Lamorake is offline
Idler Pulley won't come off - 2003 Windstar
I'm hearing a whining sound that follows with acceleration and from what I've read it may be an idler pulley, belt tensioner or alternator. I went out and bought an idler pulley and belt tensioner since it was in the budget.
I was able to get the serpentine belt loose and started to unthread the bolt for the idler pulley. Once it was out, the bolt was up against the wall of the car and I couldn't budge it. The idler pulley was stuck! I was able to get it back on without a problem.
Anyone ever run into this problem? I'd love to know a solution beyond having to take it to a shop.
Old 02-05-2012, 07:06 PM
12Ounce 12Ounce is offline
Re: Idler Pulley won't come off - 2003 Windstar
I think most folks wedge something against the engine to force the engine over to the left .... making a bit more room to remove the screw. I went back together with a slightly shorter screw.
...Just wait 'til you remove the pump!
Old 02-05-2012, 07:17 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
It does comes out, you just have to play a little with it.
When I replaced mine, If I remember correctly, I pulled the pulley form the shaft and left it "hanging" on the bolt. After that I tilted the bolt (with the pulley) towards the front and voila! It came out easily.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 02-05-2012, 08:29 PM
Thanks, 12Ounze and Oscar. I think I may have to do the ole leverage push against the engine ever so slightly and go with a shorter bolt. There was absolutely no give with the bolt/pulley to wiggle it out. Believe me I tried... maybe some of the innards have slightly different dimensions that allows for the forced pull-off.
I don't want to think about doing the pump... not going there yet! lol
Old 02-06-2012, 02:45 PM
phil-l phil-l is offline
I ran into this - and buggered up the end of that bolt trying to get it out and back in...
I didn't have the clearance to do it.
However: I had some other components off of the engine at the time - which gave the the clearance to simply remove the entire tensioner assembly itself. IIRC, there are 3 bolts that attach it to the block. Sorry, I didn't take pictures of that project - and don't recall exactly how difficult those bolts were to get to.
However, that approach dramatically simplified servicing the tensioner pulley.
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 02-06-2012, 04:50 PM
olopezm's Avatar
I'm sorry it didn't work out easily for any of you guys...
Really in my case it was very easy, both idler and tensioner pulleys were done in about 30 minutes plus 1 hour to drive to the store, get the pulley and drive back home. Even reinstalling the serpentine belt took me most of the time because I did it with a box end wrench (don't ask XD)
Oscar.
78 rear rotors won't come off tommytisme Corvette 5 12-10-2004 06:37 PM
dirt won't come off.. >< JustDoLL 3 Series 18 08-04-2004 09:36 AM
Filler Plug On Differential Won't Come Off jlseed Rodeo | Passport | MU 6 06-24-2004 09:56 PM
valve vover won't come off boostdog Off-Topic 1 02-10-2004 02:30 PM
starter bolt won't come off!HELP! bluesurf333 Wrangler 2 12-31-2003 05:28 PM
