Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-16-2004, 03:46 PM
jlseed jlseed is offline
Post Filler Plug On Differential Won't Come Off
I was going to check the gear oil in my rear differential but the plug was messed up so bad I couldn't get it off. Apparently, the previous owner managed to round off the plug to the point where the 3/8 driver will just twist around the inside. Vice grips won't work either because the plug is almost flush with the surface.
Anybody have any suggestions how I can get this plug off? I have a new one to replace it with, if I can ever get it off.
Thanks, Jeff
Old 06-16-2004, 05:36 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Filler Plug On Differential Won't Come Off
weld a 3/8 driver in? Super glue?
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 06-18-2004, 06:59 AM
danforth45's Avatar
danforth45 danforth45 is offline
you may have to remove the whole cover on the back of the differential. Its messy so be sure to have a big pan to catch the gear oil, then you can work on removing the plug right in front of you. Just be sure you buy a new seal before you put the cover back on.
good luck
97 Rodeo 4x4 3.2 SOHC V6
191k and running strong
31x10.50 Maxxis Buckshot
Manik grille guard
100w hella drining lights
Old 06-19-2004, 12:09 AM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
I have found that a T55 works great for this T-55 is a torx bit or star head as some would call it beat it in once its in you should be able to loosen it with a ratchet
Old 06-20-2004, 03:03 PM
79batmobile 79batmobile is offline
They sell roundoffs or something like that at sears. They are spiral cut sockets so they will chew the rest of the bolt up but it should be enough to get the bolt out. I screwed up some bolts on the rear of another car using an imact whrench which was tightening when I thought it was loosening. And roundouts are my last hope. So I have to believe they work. Good Luck
Old 06-24-2004, 07:36 PM
surferfletch surferfletch is offline
This one is a tough one. Tried a breaker bar, but I can't get it to budge...
Old 06-24-2004, 09:56 PM
Finally got it with someone big enough standing on the flange with the cover on the floor on a rubber mat using a socket, extension, and pipe.
