Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-02-2012, 03:16 PM
jasondicarlo jasondicarlo is offline
Rodeo spark plug question
I went to my loca parts store to but the factory Denso k16pr-p11 plugs, but they do not carry them, but did have theDenso Iridium IK16 part # 5303 plugs. Does anyone know if these will work, without tripping the p0300 code?
Or should I go online and order the k16pr-p11 plugs?
Thanks
2001 Rodeo 65k miles,
Old 02-02-2012, 04:05 PM
Cat Fuzz Cat Fuzz is offline
Re: Rodeo spark plug question
People have used Autolite double platinums without causing problems with the ion sensing. Spark plugs are simple devices. Don't give them more credit than they deserve.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 02-02-2012, 05:09 PM
Cat Fuzz,
Thank you for the information. I had put in Bosch Iridiums the other day with no change, so today I went to get the Denso's. I havent put them in yet, but decided based on all of the helpul info on here in the forums, that I would start with changing the intake manifold gaskets first and the vacuum lines, fuel lines, and coolant lines under or behind the manifold while I have it apart.
After reading on here someone stated that the majority of the 3.2 motors that had been checked had bad manifold gaskets, I decided to change them to rule that out, and low and behold the drivers side gasket is in about 4 pieces, it was a good choice to change them.
Everyone on here has been so helpful with all of the posts and useful information, that I have been trying and checking to get this thing to run decent.
Thank you everyone!!!!!
Old 05-08-2012, 05:11 PM
JBElmore79 JBElmore79 is offline
Thanks
You can use NGK plugs in the place of factory Dens plugs. DO NOT USE ANY Autolite plugs in your vehicle. NGK is specifically made for import vehicles. Autolites are made for Fords. I have worked in auto parts for several years and I see this stuff daily. If you are not sure of the Denso plugs you bought, then use a factory NGK plug. It will provide the same fire for your vehicle as the Denso plugs without throwing codes.
Old 05-20-2012, 12:28 AM
Spark plugs are simple devices. It's wire encased in ceramic and steel. Nothing more.
Old 05-21-2012, 08:01 AM
Rmasters3 Rmasters3 is offline
Spark plugs can function, but not be "right". My 2001 3.2 pinged with a supposedly better Iridium plugs. When I reverted to the Owner's Manual specified OE, the ping diminished significantly. Izusu uses the plug as an in cylinder sensor so a plug that's not right on can send incorrect or at least less accurate information to the computer. Stick with what Isuzu specified as OE.
spark plugs freakyfire05 ZX2 2 02-17-2009 11:03 AM
98 rodeo spark plug gap sathead3 Rodeo | Passport | MU 5 05-05-2008 09:25 PM
2000 Rodeo Spark plug wires HOW! troy1126 Rodeo | Passport | MU 2 02-09-2005 10:05 AM
