Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 05-05-2008, 04:53 PM
sathead3 sathead3 is offline
98 rodeo spark plug gap
I am looking to replace the spark plugs on my 98 rodeo with Denso double Platinum PK16PR-L11 plugs. Sparkplugs.com sells those gapped at .035 and they recommend that I not try to change the gap as the tip is sensitive and will likely break or get damaged. Isuzu recommends a gap of 0.044, if I am not mistaken. sparkplugs.com support say to try and use it without regapping. Is that advisable? Of course I could pay the dealer $16/plug but I am hoping to save some by buying online. Thanks,
Old 05-05-2008, 05:48 PM
Cat Fuzz Cat Fuzz is offline
Cool Re: 98 rodeo spark plug gap
Why double platinums?
I know why, just wondering if you know.
Old 05-05-2008, 07:19 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
They should be gapped from Denso at .044 the last number in the part number is the gap. 11 means 1.1mm which is .044".
Denso part number specs
I have the same plugs in mine that I got from sparkplugs.com and didnt gap them. Works fine. Dont remember if I checked the gap or not.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 05-05-2008, 08:29 PM
You should ALWAYS check the gap.
Old 05-05-2008, 09:06 PM
Thanks for the excellent info Dave. 1.1 mm it is then.
Cat Fuzz, no I dont know why double platinum. I saw some old thread on sparkplugs on this forum that mentioned that double platinum is recommended. So I went with it. I figure its cause double is better than
single platinum :-) Is there a more technical reason?
Old 05-05-2008, 09:25 PM
FL 3.2L FL 3.2L is offline
Same reason the distributorless late model TJs use double platinum plugs. Misfires. Ion sensing technology in the Rodeo. Don't know exactly why the distributorless TJ I6 like double platinum plugs.
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
