Go Back   Automotive Forums Car Chat > Pontiac > Aztek
Old 02-01-2012, 07:09 PM
driscollcolin driscollcolin is offline
code po405 po716 po717 po405
I have a 2003 aztek with 125000 miles check engine light came on got four codes po405 po716 po717and po405 in this order the only prob i have is maybe one a week when i start the car and accelerate in to go forward it takes two or three seconds however it only dose this when i first start it in the morning.
thanks for you help
Old 02-02-2012, 09:20 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: code po405 po716 po717 po405
The P0405 code indicates a problem with the EGR valve. It may be bad or dirty. You can remove it and clean it with throttle body cleaner. Make sure the tube to the EGR is not blocked. As for the other two codes the it indicates a problem with the speed sensor in the transmission. They do go bad and you should probably have it replaced. This will cure some of your issues when driving.
Old 02-02-2012, 10:16 AM
Tech II Tech II is offline
Definitely looks like two seperate problems....
Trying to remember if there was a TSB on this problem, but it should have been fixed by now........it was about the EGR freezing, and which EGR you had, top connection or side connection(Siemans)......in the tsb, you had to replace the EGR and harness, depending on which EGR you had.....
However, this code is usually about the pintle position sensor....
As for the other two codes, could be the speed sensor, the wiring to it, or the PCM....
In both cases, the only way to know for sure is with a scan tool....
Old 02-02-2012, 11:46 AM
thank for help talked to a friend who is a auto tech he said clear code drive car leave scan tool on and see what codes come back on did that and got po405 so he said replace egr valve and pray he said he seen it throw the po7117 and po717
Old 02-15-2012, 06:05 PM
now i have code po401x2 has a miss fire once and a while i took out spark plug it is white thinking needs new o2 sensor it has 120000 miles
P0304 code, rough idle, better since code charlie3 Contour 5 07-05-2006 01:26 PM
ODB code 33 and code 44 david-b Eclipse Problem Diagnosis 1 02-12-2006 09:27 PM
code 10 1988 ford separator code AbbyFord F Series 1 12-19-2005 06:10 PM
airbag code B2292 & code 33 ? 2003 Taurus ejb22 Taurus | Taurus Wagon 2 12-13-2005 05:08 PM
95 Z Code same as 94 Z Code? GeneP S-10 4 12-13-2005 04:03 PM
