Old 01-30-2012, 04:06 PM
acarinneed acarinneed is offline
92 Lumina rocker arms noisy
When accelerating 92 lumina, there was a muffled sound from the engine and the rocker arms became suddenly very noisy and loud. I suspect either the oil pump went out, its drive shaft snapped, or both. Although the oil light works when I turn on the ignition, it never came on after this noise began (drove it the 2 blocks home). The dipstick shows full. Ideas? Thanks!
Old 01-30-2012, 04:14 PM
DeltaP DeltaP is offline
Re: 92 Lumina rocker arms noisy
Worst case... somethin broke in the valve train or the cam snapped.
Old 01-30-2012, 04:18 PM
If either of those were the case (esp broken camshaft), would it even run? After parking it, I started it back up for a couple seconds. Other than the very noisy rockers, it seemed as though it ran pretty well.
Old 01-30-2012, 04:36 PM
What engine ya got. If the rear cylinder lobes broke off it'll still run. Shirty but it'll run.
Old 01-30-2012, 07:05 PM
Blue Bowtie's Avatar
Registered Offender
If it's a 2.8 or 3.1 V-6, you might have this problem:
This one ran well enough to drive into the shop just as you see it.
Old 01-30-2012, 07:10 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
I agree with the original assessment....I bet the oil pump fragged.
I'd probably start by disabling the injection and pulling the oil pressure sensor out, see if you get any oil pumped from the hole when cranking the motor. If not, you'll be pulling the pan to see what happened.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 02-01-2012, 10:26 AM
jimbob0077 jimbob0077 is offline
Shouldn't you pull ignition wire at coil one at a time to see if there is one cylinder that is not producing the same amount of power? Does it have a idle miss?
1999 chevy truck cold adjustment for rocker arms, It has the 350R eng. dchapman37 Silverado 1 01-12-2005 01:32 AM
where can i get rocker arms???? djextreme68 Off-Topic 3 12-12-2003 04:30 AM
Head problems - Pin in Vtec rocker arm Sheared off 5_LiTeR_EaTeR Engineering/ Technical 0 07-18-2002 11:47 PM
Adjusting Rocker Arms. Rich General Discussion 9 06-24-2002 05:23 AM
Adjusting Rocker Arms. Rich Engineering/ Technical 1 03-04-2002 12:49 PM
Tags
arms , noisy , rocker
